SaleenGT2001
Well-Known Member
so whats the offical word on the UPR pro series lowers? i'm looking at getting just the lowers for my car.
Nope, unless you have specific goals at the track and you wanna run some real tread
If your set on some suspension go FL SFC's
I plan on running my car at the local dragstrip.
Thanks for the feedback. I guess the only way to find out is to see what happens when I go out there for the first time. I plan on racing with street tires so should I avoid the burnout area?
dont drive through the water box, but do a quick little burnout just to get all the dirt, rocks, & debris off your tires....
I agree that SFC's would be a better 1st suspension mod, but LCA's are a great mod too. Just make sure that if your gonna be running your car at the track, get the MM extreme duty LCA's because u will blow out the poly bushings on the Heavy duty LCA's, quicker than u will blow out your stock rubber bushings on the stock LCA's....
I'm goona take my car to the track rarely, not as often as people think. What would be the best, stalling or flashing the converter to get better ET's?
Yeah, Thanks for you input man. I'm just trying to gather as much info that I can to get the best set up for my car.
No prob....
I just noticed your in Fresno... what track are u going to? I live in Sacramento btw....
I really dig your sig pic too, where did u get that??
with a stock TC, you dont really need to worry about what it's doing. Just rev it up to as much as your tires and suspension can take w/out burning out at the launch- and lift off the brake. Took me a few runs just to dial in where i should drop it from, it depends on where you make your power and the stall of your TC. I forget what i dropped it at cuz my tach wokrs on and off, lol.
DO NOT BUY UCA..... Just get MM LCA and stock uppers..... Maximum Motorsports recommends the same thing
I believe my stock converter stalls up to 1500rpm before my tires starts to spin. What SFC's do you recommend? Get your tach fixed man, lol.
