Do I have all I need for brakes?
Fox_84
143
I am going to the junkyard Friday and need to know what I am forgetting or if I have something wrong? Wanting to go 5 lug, 4 wheel disc, and do it the best way possible. If there is something I am forgetting or have something wrong, let me know PLEASE AND THANKS in advance. And o yeah, I am wanting to keep the stock track width front and rear.
1. spindles from a 94 or 95 v6 or gt.
2. calipers all 4 from a 99-04 v6 or gt to get dual piston setup front and rear both from this year.
3. rotors to fit a 94-04 v6 or gt
4. master cylinder from 94-04 v6 or gt
5. proportioning valve from 94-04 v6 or gt
Is this all I need from junkyard?
I already have the brakets for the calipers on stock length superior axles 31 spline at factory track width in the rear.
What else will I need? Feel free to correct anything you see that wont work. Thanks. and I know you have to do a little fabrication on the front calipers to get them to bolt on, what is this all about???
Thats most of what you will need. One thing though, don't get the PV from a 94-04, you will need to gut your stock PV and get an adjustable PV to add between the MC and rear brakes to set the front-rear bias. You will also need to get the e-brake cables and modify your e-brake hande to work with them.
Here's the part #'s for the e-brake cables- FMS M-2809-A (x2) & FMS M-2810-A (x1) and the FMS M2450 plug (x1) to complete your stock PV. Also since there is a difference in the size of the rear rotor and hub, you need a spacer to center the rotor. Find a pipe that is 2.5" ID, 2.75" OD and about 3/8" tall to use. Go to Matt's site, it will have all the info you will need - http://mjbobbitt.home.comcast.net/mustang/5lug.html.
