  • SN95 4.6L Mustang Tech
Do I need to upgrade to 8-rib pulleys?
  • Thread starter Thread starter spoc8hi
  • Start date Start date Mar 2, 2008
spoc8hi
22
mobile alabama
Mar 2, 2008
  • Mar 2, 2008
hi guys, i have a vortech v1 s-trim and i want to achieve 14-15 psi. im told by a friend that with any pulley smaller than a 3.33, the belt will slip. is there anyone here making this kind of boost with the standard 6-rib pulleys? a 2.8 should produce this kind of boost, right?
04YELLOWGT
1,135
Indiana
Mar 2, 2008
  • Mar 2, 2008
Yea you are going to need an 8 Rib-Kit.
C
Chris00GT
275
York Springs, PA
Mar 2, 2008
  • Mar 2, 2008
I'm running the 3.12 with my V2-SQ on a 6 rib and having no problem with belt slip. I'm running a regular NAPA belt that is as tight as I can fit on and making around 15lbs of boost.
the98stang
2,408
Clovis, CA
Mar 2, 2008
  • Mar 2, 2008
Your friend is wrong...I run a 2.8 pulley @ 14psi with no problems at all. You should be fine....
spederman
732
  • Mar 2, 2008
its always good to upgrade to 8 rib below 3.33 pulley in my opinion. I was having belt slip with my 3.2 pulley and upgraded to the 8 rib. Even if you dont see noticible belt slip, the 8 rib conversion will make the boost hit a lot harder and at a lot lower RPM then the 6 rib. If you can afford it, might as well do it.
BennyBlown2v
1,233
Carmel, INdiana
Mar 2, 2008
  • Mar 2, 2008
I think both of you guys are the exception, heh. I ran a 3.12" with a NAPA belt and it didn't slip much, but it did on the dyno, and it did when down shifting them slamming into the throttle. So yeah...you don't NEED the 8-rib kit, but it will make the power come on sooner, and be waaay more steady. All of us vortech 2v guys are pretty lucky though, at least we have AWESOME belt wrap with the stock 6-rib setup - it's waaay worse with a v-belt car (like a 302).
SilverBullet00
1,150
Wichita, KS
Mar 2, 2008
  • Mar 2, 2008
I have a RR no slip pulley and it works great. One day when my ish is running good I am going to see what their 2.9 " will do!
i thought about going 8 rib with my current setup, but its just too much work for me right now
spoc8hi
22
mobile alabama
Mar 2, 2008
  • Mar 2, 2008
you are all using 113" belts right? vortech recommends a 112.8" with the 3.33" pulley but the closest that i could find was the 113" and im afraid that if i go down to a 2.8" pulley that my belt tensioner will be maxed out.
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
H
Vortech V1 Idler Pulley Newedge
  • HIGHMILE2V
  • Sep 12, 2024
  • The Welcome Wagon
The Welcome Wagon Sep 13, 2024
HIGHMILE2V
H
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Forced Induction Vortech bypass valve necessity
  • 92Rustang
  • Aug 28, 2024
Fox 5.0 Mustang Tech Sep 2, 2024
Cheapskate207
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
