Do these rocker arms look good or should I spend more ?
Rusty67
Dec 3, 2002
3,749
37
109
LA, CA
I was checking some stuff on ebay. I'm looking for a set of full roller rockers to use with my D0OE heads. I'm going to use the motorsport valve springs:
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=1257
I'm also going to be using the motorsport F cam. I'm wondering if any of these rockers are worth my time of if I should spend some more money on a "brand name" set of roller rockers.
These are what I found:
http://cgi.ebay.com/ebaymotors/FORD...tegoryZ33624QQihZ017QQitemZ270015385232QQrdZ1
http://cgi.ebay.com/ebaymotors/ALUM...tegoryZ33616QQihZ013QQitemZ230014608830QQrdZ1
http://cgi.ebay.com/ebaymotors/302-...tegoryZ33624QQihZ004QQitemZ140014432528QQrdZ1
Am I wasting my time with these or are they every bit as good as say comp cams stuff for 100 dollars less ?
Even though I use eBay a lot, I am wary of buying rocker arms there. I was across the aisle from Scorpion at last year's PRI show, and the owner was telling me some pretty scary tales. He said almost all his returns were from knock-off Chinese rockers that people bought on eBay. He also told me about a prototype Chevy Gen III rocker he had on his display stand at PRI the year previous, and someone stole it off his display. 6 Months later, it was on eBay, in sets, even though he decided not to manufacture that part.
I would buy my rockers from a reputable manufacturer and a reputable source. The ones you are looking at are less than $150 at Jegs all day long.
I am going to go with a 7/16" stud as it is. I believe all of those rocker arms used a 7/16" stud.
I guess what my question is, are any of those as good as a well known brand name full roller rocker ? I'm trying to put together a good set of heads on a budget. If those rockers are not gonna be capable of performing the same way a set of comp cams rockers would then I have no problem paying the extra cash. But if they are every bit as good for 100 dollars less then why should I shell out the extra money ?
