My question is..does a stall converter always slip a little? Lets say you eased on the throttle, do you actually get anywhere till 2800 rpm or so? Does it feel a lot slower than stock or does it not slip unless your applying brake pressure?
umm don't think that's right. it doesnt' matter if your o/d button is on and you floor it from a stop. the button just allows the trans to go into o/d when it needs to. you're just not supposed to use o/d as an accelerating gear. so you shouldn't floor it, top out 3rd and let it shift into fourth when you're still flooring it because it's a cruising gear and isn't strong enough for that... that's just what i've heard, but it makes sense.sonicblue87lx said:Although When im in o/d I was told not to slam on the gas cuz it will just spin the convertor i was told if i want to just floor and go to take off the o/d. But if im on the express way i can feel that gear kick in then i can just go with it then.. Its wierd if you ask me but no less I like the convertor
95Vert said:Good read.
ccoypat said:I installed a custom built Edge 9" 2870 stall (lock-up/2.42 stator) TC in my car about six months ago. You can tell the difference when you first accelerate (slowly) from my stock one. You move when you press the accelerator just like a stock converter, but you can tell it is not fully engaged until it hits 2870RPM. Almost like it slightly drags. It took some getting used to. Other than that and WOT, you won't tell too much of a difference from you stock converter in daily driving.
Later
sage2k said:What gains did you get from that converter?
Did you lose any mpg?
