Does your Car ever run hot(wen cool outside)
well last nite wasn't so bad, it stayed in the middle of gauge to upper part even when on freeway, idling was bad, it used to never go past the A, now its going to the L, i checked at my friends shop tho the fan use to kick on at 217 degrees at the A, i think i should check if thats still working i just have a stock style radiator, , could i get a 180degree thermostat?
If truly running hot on the highway and in town, and all ancillary items are up to par, it sounds like the radiator is simply not rejecting heat like it should (like RC said).
I would want to diagnose further, but based upon what I remember here, it sounds likely.
A cooler rated stat is not likely to fix anything, but rather just give you a few more minutes before it reaches these temps.
Good luck.
You should think about getting an alum radiator. The Fluidyne is a popular choice and a real easy install. It costs a penny, but its worth it.
when was the last time you flushed the system, the whole thing? flush it, put new coolant in and add some Water Wetter, that stuff helps.
get a new cap, and 180 stat.
