  • SN95 4.6L Mustang Tech
Dogbone removal
  • Thread starter Thread starter ponysarepretty
  • Start date Start date Oct 29, 2005
ponysarepretty
578
  • Oct 29, 2005
I'm going to get this done in the next few days and from what I gather it is safe to put the top bracket back on and i need a shorter bolt to do that. What size bolt should i get, could i get it from like home depot? I would like to pick it up first and do the job in the garage rather than in the parking lot of home depot.
White Stang
467
Ft Lauderdale
Oct 29, 2005
  • Oct 29, 2005
The dog bone is suppose remove some rear end noise. Just remove the whole thing. Definatly remove it after a gear swap. Its a few pounds your stang doesn't need.
ponysarepretty
578
  • Oct 29, 2005
No the top braket thing apparent prevents bad stuff happening if you get wheel hop.
And it seems to be impossible to remove.. damn rusty
J
Justin03GT
199
Mount Pleasant, SC
Oct 29, 2005
  • Oct 29, 2005
its pretty tough to get wheelhop in a solid axle car with quad shocks...just take the whole thing off...
DropTopPony
Noob Slayer
2,570
south jersey
Oct 29, 2005
  • Oct 29, 2005
the bracket holds the bump stop doesn't it.
M
MustangLife
1,285
Chattanooga, TN
Oct 29, 2005
  • Oct 29, 2005
I had bad wheel hop in my car with the stock upper and lower control arms, but my quad shocks were busted. But my aftermarket uppers and lowers put a stop to that. But if you drag race and still have quad shocks there probaly busted anyway.
I've always heard the only way you should remove the dog bone is if you get a aluminum driveshaft.
Josh
ponysarepretty
578
  • Oct 29, 2005
they don't make an aluminum driveshaft for autos
ProCharger GT
153
Cleveland
Oct 30, 2005
  • Oct 30, 2005
you can put an aluminum with an auto, slight modification to the linkage...i know there's a thread on here about doin the conversion
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 30, 2005
  • Oct 30, 2005
isn't that what he's talking about?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Oct 30, 2005
#10
  • Oct 30, 2005
  • #10
Yup. I have an aluminum driveshaft in my 01 GT, and it is an automatic. Just buy the driveshaft recommended for the five speeds, and swap yokes. That is all there is to it.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
