doing tune up help
  • Thread starter Thread starter JeepinXj87
  • Start date Start date Mar 11, 2004
J
JeepinXj87
210
maryland
Mar 11, 2004
  • Mar 11, 2004
ok guys im going to run out to pep boys to get what need to do a tune up ddo u guys recommend any certain brand name when it comes to cap rotor, and what kind of plugs and wires should i get ....... how much u think it will cost for all of this and is there anything im missing
i have a cold air intake so do i just clean the filter
Blowfish
11
S.F. bay area
Mar 11, 2004
  • Mar 11, 2004
Go to www.performancedistributors.com and check out the 5.0 firepower kit. It has everything you need plus a new screamin deamon coil, livewires to handle the bigger spark , dyna mod module with bigger dwell, cap and rotor are all brass connections and comes in colors. I put the kit on my 92 mustang and felt the difference right away. It costs more than pepboys but I got my moneys worth. You can run your plugs with .065 gap with the bigger spark . good luck
IMissMy93Fox
143
  • Mar 11, 2004
I try a Ford dealer, I know McCarville Ford, on L.I. so it doesn't really help you but they have a tune-up package. You can also order from them, they got an ad in 5.0... actually I just checked and of course it's not in this months.. well anyway if you can wait a few days for it their number is 631-588-1800. Sherwood Ford should have it too IDK how close that is to you though.
ninety15.0
1,336
  • Mar 11, 2004
I just did a really good tune up on my 91 and this is what i did.
Autolite plus- $30 somethin bucks
Wires- $45
Cap & rotor -$20
pcv valve- couple bucks
Fuel Filter - $8
change oil
clean air filter if K&N or replace if not
clean throttle body and MAF
Adjust idle then set TPS to .94-.99v
thats all i can think of right now but thats a pretty good start. good luck man
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
15K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
  • dan50
  • Jul 18, 2026
dan50
