http://www.outperformanceshop.com/product-p/tremec-tuet11430.htm
TREMEC TUET11430 Ford Mustang S197 T56 Magnum Transmission Conversion Kit
Closer Ratio Gears:
1st Gear = 2.66
2nd Gear = 1.78
3rd Gear = 1.30
4th Gear = 1.00
5th Gear = 0.80
6th Gear = 0.63
Rev Gear = 2.90
TREMEC's newly released transmission for 2011. This is a new addition to the T-56 Magnum line-up designed exclusively for 2005-up Ford Mustangs!
Known unofficially as the ‘S197 Magnum’, this new 6-speed model will feature a ‘direct-shift’ extension housing designed to eliminate the notoriously unpopular semi-remote factory shifter. Additionally, a slip yoke style interface will also make it easy to ditch the equally unpopular 2-piece driveshaft in favor of a more robust 1-piece arrangement.
As with all Magnum 6-speeds, TREMEC aims to put a 700 lb-ft. ‘seal of approval’ on the new Mustang units, and will eventually offer them with both Magnum ratio packages to suit a variety of street and performance driving scenarios.
Great solution for 2011-2012 Ford Mustangs with fragile factory Getrag MT-82 transmissions!
From TREMEC's Brochure:
Coming late summer 2011, the foremost name in performance manual transmissions, TREMEC, is releasing an all-new 6-speed aimed specifically at S197 Mustang enthusiasts! The new 'direct-shift' T-56 Magnum for 2005-up Ford Mustangs* represents a long awaited solution to the semi-remote shifter woes experienced by many 2005-up Mustang owners, as well as, TREMEC's most significant foray into the Mustang aftermarket since the days of emerging 5.0 Fox-body performance.
Designed almost exclusively with S197 Mustangs in mind, this new model draws from a combination of proven OE (Shelby GT500) and racing (Grand Am Cup) technologies. Featuring an application specific 'direct-shift' extension housing, the Magnum solves the issue of numb, inaccurate shifts offered by the factory semi-remote shifter, replacing them instead with crisp, clean, confidence-inspiring throws. The S197's exceptional driver ergonomics are maintained, along with the added ability to custom tailor shift action thanks to TREMEC's innovative 'adjustable-bias' short throw shifter--standard on every new assembly!
Other significant features include a slip yoke rear interface, eliminating the need for complex 2-piece driveshafts, and an SFI-approved steel bellhousing for added safety in high-horsepower applications! Installation is simple thanks to thoughtful design by TREMEC engineers and a TREMEC-supplied swap-specific crossmember. In most cases users can even retain their factory clutch release system!** Like all Magnum-series transmissions, the new model carries with it a generous 700 lb-ft. torque capacity rating, and choice of two exclusive gear ratio combinations.
*2011-up models require speedometer recalibration.
**2005-2010 Mustang GT. Others will require minor modification
Closer Ratio Gears:
1st Gear = 2.66
2nd Gear = 1.78
3rd Gear = 1.30
4th Gear = 1.00
5th Gear = 0.80
6th Gear = 0.63
Rev Gear = 2.90
