Stanger007 said:I've got a gauge on mine - all is good. Before you spend the money on a gauge and rail adapter, it might be cheaper to find a mechanic that could check it quickly for ya. Just hindsight talking.
EDIT: I got my gauge and rail adapter from Summit - I found the P/N's by searching this forum.
Mustangless:
How'd you like your shift-kit? Did you install it yourself?
before i bought the autometer electric gauge, i used one i got from the local auto parts store that screwed right into the schrader valve. if my memory serves me right (going back 3 years), i paid about $20 for it.Mustangless said:Mine is an aode but it is not a convert. I think I am about to buy a fuel pressure guage and check that. My gas milage is also very bad.
where can I get a cheap fuel pressure guage?
Green 94 5.0 said:i had the same problem too. the fix for me was pitching the AODE in the trash and bolting up a T5. mine was a torque converter issue. rather than blowing the cash on a performance converter though, i opted for the 5spd swap.
http://ridewithdrc.com/roger/mustang/trannyswap/
Synned said:I really really really think that my problem is
7. ATF level low causing slippage
It really feels like slippage. It's only down on power in the low rpms. So I think that the torque converter is slipping untill it locks up harder when it gets to higher rpms.
the gas mileage was horrible.Mustangless said:was your gas milage also bad or just performance? I have been thinking about getting a new TQ.
your transmission fluid may be low. that will cause the torque converter to slip even if the converter is in perfect shape. and there is nothing to be afraid of about the t5 swap. i had never removed a transmission from a car when i did mine. the hardest part in my eyes was changing out the pedal assembly.Synned said:I think it might actually be the converter. I think it feels the exact same for me as someone is feathering the clutch, although not as drastic. So maybe I'll just get a torque converter. What about changing the fluid in the converter? Did you try that? Does it share the same fluid as the tranny? I'm scared of a t-5 swap.!
. I have ran seafoam and nothing is better. I am not certain but above 2k rpms it seems to pull harder. I really am thinking about ordering the cheaper edge tq. I just don't won't to spend all that money and it not fix it.
