  • SN95 4.6L Mustang Tech
Dr. Gas X Qs
  • Thread starter Thread starter hotmustang331
  • Start date Start date Nov 15, 2004
hotmustang331
2,967
Bastrop,TX
Nov 15, 2004
  • Nov 15, 2004
Ok I will be buying a Dr gas X pipe probably tonight.But I few questions first. ONE: will it bolt right up to my stock manifolds and stock catback? TWO: I will be installing a magnaflow SS catback not too long after, and will its flanges bolt right up? THREE: I have an 04 GT and will it work with 04s...their site says 99-03.SLP's catted X says that i need extentions for the O2 sensors ONLY on 04s, so do I need these on an O/R X, or do I not put the O2 sensor into the O/R? (BTW I know I need MIL elims) FOUR: Anyone have any dyno testing or experience with the Dr Gas X, and if so please let me know how much power you gained and your opinion about quality and such. FIVE: Where is the best/cheapest place to buy one. Thanks VERY much for your posts and help.
sacstoy02gt
124
Waukesha, WI
Nov 15, 2004
  • Nov 15, 2004
1. Yes, it will bolt up. But, you'll want to get Napa Part#600-1819 header stud kit and get rid of the crappy shouldered studs. You'll want 4 clamps to clamp the x together where it fits right. Then take it and get it welded together or weld it together yourself. (It comes in 5 pieces, unless they now have one pre-welded)
2. Won't be a problem.
3. You'll put the o2 sensors in, you'll just need extensions for the front o2's. You'll want MIL eliminators(splice-in is cheapest) to stop the check engine light from coming on since there won't be any more cats.
4. I had a Dr. Gas on for a while, but a leak that I could not fix due to me buying a used pipe made me pull it. If I get a chance again, I'd put a brand-new one on there. Awesome power gains(SOTP) and incredible sound!!!!
5. www.modularpowerhouse.com
hotmustang331
2,967
Bastrop,TX
Nov 15, 2004
  • Nov 15, 2004
Hey THANKS very much, that helps out a bunch.Only thing to make sure about is Q# 3, So I HAVE to buy those $29 O2 extenders?i was thinking that you only needed extentions for LTs on the front O2s. Now its the rear O2s that needs the MILs, but its the front that need ONLY the extentions, even with factory manifolds? So all parts needed are MIL elims, extentions for front 02s, and some welding rods.BTW what rod should we use, a 7018 or a 6011.thanks again.
sacstoy02gt
124
Waukesha, WI
Nov 15, 2004
  • Nov 15, 2004
Yep, you're right on the parts. You could probably make everything you need on your own. o2 ext. are just longer wires, and MIL elims are just some parts from radio shack. Search on MIL elims, you'll find the diagram and parts list somewhere.
I would go with a 6011 rod. 7018 is more of a filler rod.
J
Jay99
73
Sac/Rancho
Nov 15, 2004
  • Nov 15, 2004
hotmustang i pm'd you let me know if you want the pic
hotmustang331
2,967
Bastrop,TX
Nov 15, 2004
  • Nov 15, 2004
Thanks Jay, I PM'd you back with my Email.Had to reset the account due to my not using it much, but its up now.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
G
Engine At the end of my sanity. 92 GT on jack stands for the last 11 years - NO START
  • Green 94 5.0
  • Apr 13, 2024
3K
Fox 5.0 Mustang Tech Apr 24, 2024
FastDriver
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
P
Thoughts on this odd (smog legal) combo?
  • PJV9126
  • Feb 8, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 16, 2023
91AOD5.0LX
