Drawbacks to rough idle?
The tech guy at comp has suggested a specialty cam the 260AH. He said its very similar to the XE256H, just has tighter lope separation which makes a rough idle, while the XE256H has a smooth idle. I'm trying to decide cams. Is there anything else to the rough idle besides the sound?
That rough idle or lumpy idle is due to valve overlap. Valve overlap is when both then intake and exhaust valves are open, which allows your engine to breath at the higher RPM range. When the exhaust is forced out by the piston it creates a vacuum, which will help drawn in more air/fuel. The downsides is that not only do you have less vacuum available at idle like SD said, but you also will have horriable gas mileage(at idle the gas is pretty much getting blown right out the exhaust port, starving the engine, hence the rough idle) plus a slower throttle responce off idle.
-Shaun
2nd Mustang said:
That lumpy idle is oh so sweet! Throttle response is pretty good too. I vote for lumpy.
I have yet to hear one with good throttle responce off idle...unless it had some type of forced induction of course. Instaed you get a big hesitation, to the point were the engine sounds like it has died. But you're right, that lumpy idle sounds sooooooooooooooo good. :drool:
-Shaun
-Shaun
I blip the gas once before letting out the clutch from a dead stop. Holding the gas down at 1500 to 2000 rpms just spins the tires for me.
i wouldnt be concerned about the idle on the XE256H, its basically an RV cam. its also about the biggest i would run with stock springs. if this is a daily driver, then you should be ok. if you want a stong cam, get smaller durationw hile maintaining high lift. this way you get good torque and high top end. a 289 doesnt make much torque, so dont plan on wheelstands. and remember, a cam is only one part of the machine. it takes more than just a cam to make horsepower
i have a single pattern crane cam with .488" lift, 110 lobe and .218 duration at .050 and mine has a wide range of power. however, ive done more than just a cam swap. ive ported the heads, engineered an exhaust system, as well as modify the intake and ignition system. my biggest bottle neck right now is the small valve sizes and small runners. i imagine that 330 hp is the most ill get out of my engine until new heads are put on
-Shaun
Speak for yourself, my lumpy idle motors all have excellent off idle response. It's all in the carb tuning.
slapstick humor
SuperDave said:
I just couln't resist interjecting a little "bathroom humor"! This forum often becomes so serious! :rolleyes: :rolleyes: :rolleyes:
SD;
Thanks for the good old slapstick humor, you have earned the right to do that in here. I just mention in another post about missing hungrymonkey and his slapstick humor, and now you take up the slack. Keep it up, a good laught does good for all of us. you have helped alot of us on our serious questions. :spot:
68 dailydriver :spot:
68 daily driver said:
SD;
What no one thought my spilled coffee crack was funny
:shrug: :(
There's not much chance of any cam with that little advertised duration causing you any greif at all. I'd be shocked if you could even tell it had much lope to it at idle. You'd need to get around 230 degrees duration @ .050 lift before you'd need to be even a little concerned about vacuum accesories, etc. My '65 had a hydraulic flat-tappet cam with 236 [email protected] lift and still did just fine with power brakes. My opinion about Comp is that they make THE best street cams there are, and you'll be just fine with that one. OK, now back to the potty humor... :D
