I have the T-5 in the stang now with the crossmember I made; however, I want to check to make sure that the driveline angle is correct. How do I do this? I remember reading that to maintain the original driveline angle, you had to cut the tranny tunnel becuase the T-5 sits 1" lower then the stock tranny, but that you could fix this by changing the pinion angle. Anyone got anything on checking to make sure that it's right?
-Shaun
-Shaun
