DRIVER DOOR ISSUES??
lzrrd
Arizona
I have a 2004 gt that i just bought. i can’t find anything about the issue. when i bought the car the driver window didn’t work so i replaced the motor. it worked for a couple weeks and then stopped working again. i was told it could be a wiring issue within the door. does anyone know what might be causing this and is it fixable? will it keep happening if i fix it? the passenger window button works just fine and when i press the driver window button it makes a clicking by the fuse box. replaced the fuse in it to eliminate that issue. could it be any other issue besides bad wiring? i appreciate any and all help
  • Sponsors(?)
HemiRick
I'd be looking at jacking under the house
Jun 28, 2020
723
290
73
58
Memphis TN
gonna hafta do some testing could be switch motor fuse wiring. Got a DVOM?
Reactions: 1 user
manicmechanic007
Mustang Master
Sep 26, 2017
1,696
476
93
62
Could just have a shorted master switch (the drivers door window switches assembly)
The clicking in the fuse panel is the circuit breaker breaking because it senses a short
The wiring into the door from the kick panel (inside the rubber boot) is a common wire break / short location
Interrogate those wires while observing the fuse panel
Get a new switch to test with
Right out of the ford manual to substitute a known good part
Bitchy repair those wires are
Everyone needs a DVOM and some practical knowledge about using one
