  • SN95 4.6L Mustang Tech
Driving a stick...
  • Thread starter Thread starter merc123
  • Start date Start date Jan 6, 2004
  • 3
  • 4
1 of 4 Next Last
merc123
420
North GA
Jan 6, 2004
  • Jan 6, 2004
I've tried searching the internet to no avail on this subject.
I'm curious about how to drive a stick. My dad tried teaching me when he had a ranger which was fine, but just the basics were taught.
What I'm interested in is:
How/when to downshift @ stop signs/red lights and when on mountain/curvy roads.
What wears out the clutch? I've heard just holding it in all the way while waiting at a stop sign will do it. Give me all the scenarios please.
I've always just learned to put it in N and let off the clutch.
All the help I can get will be appreciated. I hope to get a mustang within a few months as my $$ has finally arrived! Weee!
Beau
3,050
San Diego
Jan 6, 2004
  • Jan 6, 2004
i learned not to hold in the clutch for any long period of time at all. the only time the clutch should be in is when you're changing gears or starting the car up.
as for when to shift...i just play it by ear when going up through the gears, unless i really want to punch it..downshifting, i also just go more with my SOTP meter, meaning i go by instinct..whether or not my instincts are correct or not is very very debateable...
merc123
420
North GA
Jan 6, 2004
  • Jan 6, 2004
Going up isn't a problem. I can do it by ear as well. Going down is what I want to know about. I want to know the actual mechanics of what is going on. Kind of like when someone explained heel-toe shifting.
Beau
3,050
San Diego
Jan 6, 2004
  • Jan 6, 2004
well i would imagine that downshifting is just the reverse...you're getting your slower spinning engine to slow down your faster spinning wheels...as you can see that would put a big load on both engine and transmission but i do it all the time when exiting the freeway and in other situations
merc123
420
North GA
Jan 6, 2004
  • Jan 6, 2004
should I tap the gas to try to match RPM's of the lower gear so it's not just a big jerk?
23 Stang
41
Chicago, IL
Jan 6, 2004
  • Jan 6, 2004
Not quite sure what you're asking, but I'll give you a couple of scenarios...
As for downshifting, I really only downshift on turns, i.e I might be in 3rd and when coming into the turn I'll depress the clutch on the turn and put it into second coming out of the turn and disengage the clutch.
I also will probably downshift when I'm passing someone, lets say I'm going 45-50 in 4th at 2-3x1000 rpm and I want to get some extra juice, I'll probably drop it into third and pass or accelerate faster.
Just my 2 cents, I try avoiding being in neutral all the time, in good conditions it's ok to put the car in neutral and roll to a stop/red light. But since it's been fairly bad weather here in Chicago lately, I try keeping my car in gear the majority of the time and break with the engine most of the time. It's very dangerous when you're in neutral and you have no power to the wheels and don't have time to get into gear. In bad weather, also try to keep it in the highest gear possible.
Also, unless you drive stick regularly or used to own a stick car, you shouldn't expect to be an expert. It all comes with time and practice, the more you drive, the better you will most likely be, i.e the first couple of weeks I have my car I'd avoid left turns and nasty hills. Time builds confidence.
Hope this helps, somewhat.
4.6MustangSteve
219
Northern VA, USA
Jan 6, 2004
  • Jan 6, 2004
I blip the throttle on downshifts to rev match.
Beau
3,050
San Diego
Jan 6, 2004
  • Jan 6, 2004
thats exactly what i do...
merc123
420
North GA
Jan 6, 2004
  • Jan 6, 2004
I've tried to blip downshift but I usually wind up just slamming on the brakes because it doesn't slow down enough I guess I'll give it a while when I get it. A buddy of mine was driving his Talon fairly well in about 3 days.
Shorin
Tucson, AZ
Jan 6, 2004
#10
  • Jan 6, 2004
  • #10
have done this for years on my 4x4 truck, now that i have a mustang i still do it. less jerk on the drive train, less wear on the clutch.
if you hold in the clutch while at a stop you are constantly having the throw out bearing spin when it doesnt need to. dont hold it until you see the other light changing
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 6, 2004
#11
  • Jan 6, 2004
  • #11
What I do is blip the throttle if I'm just slowing down a bit like going from a 55 to a 45 speed zone....or if a curve is coming up that requires a little less speed....if I know I'm coming to a stop I just stick it in neutral and slowly brake to a stop....
David
merc123
420
North GA
Jan 6, 2004
#12
  • Jan 6, 2004
  • #12
Just gotta be careful the car doesn't stall when I put it in neutral as the 03 has a tendency to do
Rustang Cobra
490
Lexington, MA
Jan 6, 2004
#13
  • Jan 6, 2004
  • #13
i double clutch my downshifts, i dont just throw it into a lower gear and release the clutch
scenario:
your going 40mph in 4th and wanna engine brake for a turn coming up
-clutch is out and car is in 4th
-push in clutch and put shifter to N
-let out clutch
-blip throttle to bring up revs to where they'de sit in 2nd gear at 40mph (about 4k)
-push in clutch and throw it into gear and let out the clutch swiftly but smoothly
if done correctly you wont feel a jerk, but just the car engine braking smoothly
by double clutching your downshifts you put less wear on the syncros in the tranny that would otherwise have to match the revs for you in the gear your changing to
Sleepy1
807
Chicago, IL
Jan 6, 2004
#14
  • Jan 6, 2004
  • #14
Why double clutch when you can do that in one smooth movement? Just give it a little gas to rev match. You will learn with time what different speeds go with which gear.
merc123
420
North GA
Jan 6, 2004
#15
  • Jan 6, 2004
  • #15
I do it in one smooth movement. Just too slowly for it to work right I only go down one gear also instead of maybe 2 or 3.
LI98GTStang
1,715
L.I., NY
Jan 6, 2004
#16
  • Jan 6, 2004
  • #16
Whenever I want to know how things (stuff) work, I start on stangnet if it's mod related and directly here if not.
http://auto.howstuffworks.com/clutch1.htm
I've been driving a stick for many years/miles now and don't even think about it anymore really and still enjoy driving with them. The advice you have been given so far is good to go. For long clutch/throw out bearing life, you don't want to push in or rest your foot on the clutch. As with everything in life, moderation. So you don't want to pop the clutch when disengaging or let it out too slowly either. Just a little practice and you will know when you got it right. Also your passengers will complain if your driving it too jerky incase you don't notice. Aside from taking off quickly and properly, nailing down each shift, there is hardly a better feeling when you execute the perfect brake/downshift/turn then back on the gas again. And yes blipping the gas to match those revs.
wjfawb0
929
Georgetown, KY
Jan 6, 2004
#17
  • Jan 6, 2004
  • #17
I tried to get my fiance to understand by teaching her how motors, trannies and clutches work. IF you understand the parts and how they work together, you can figure out what you are supposed to do. I dunno how much you know or have seen, but if you go to howstuffworks.com and look in the auto section you can see some good animations of drivetrain parts in action. It helped my woman to understand what was going on in my car. That got her where she could almost drive a stick.
-Jason
FallenPhoenix
911
Odessa Tx
Jan 6, 2004
#18
  • Jan 6, 2004
  • #18
I've just learned some things in this thread and I've been driving a stick for ~6 months wrong. Good thing I learned about not holding in the clutch before I get the 'stang, I'm going to baby that thing.
Sleepy1
807
Chicago, IL
Jan 6, 2004
#19
  • Jan 6, 2004
  • #19
Totally agreed with LI98GT. It takes practice, but after awhile you just don't even think about. Nothing beats being able to drive down the road and being able to downshift into any gear you want without any jerking.
merc123
420
North GA
Jan 6, 2004
#20
  • Jan 6, 2004
  • #20
What is the resting the foot on the clutch I hear about. Is that as simple as it sounds of simply resting your foot on the clutch when it is out?
Good stuff with the howstuffworks.com. I forgot about that. Never understood how the manual tranny worked.
  • 3
  • 4
1 of 4 Next Last
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
