Dyno Results... I need 2 more HP!!!
meth injection. then you can be more agressive with the timing, or not. in either case though, it gives you more options ... (1) it can easily add probably up to as much as 50 hp, and (2) makes for a little more safety because it really cools the intake charge, so you will be less likely to detonate.
block safety is mostly in the tune.
I'd like to get the meth injection but I am afraid of "Too Much" HP coming from it. I'm already playing with my blocks life. The HP from the Meth would be like playing russian roulet with one hole empty in the cylinder. Is there anyway You could just use the water/ meth as a coolant and not a means of creating more power? Also what would I need the snow stage 1 or 2?
the methanol itself doesn't add the power, it just cools the charge. the power comes from the ability to then add more timing. if you don't want more power, then don't advance the timing. you are still safer because the intake charge is cooler.
or you can inject just water if you don't want to use methanol. that will cool the charge too.
