Dyno'd the vert today here are the number's
sgthooligan
24
Went to the dyno today to try and solve the 8 miles to the gallon problem that I have been having. The first run it pulled 258 hp. The fuel pressure was at 42 lbs with no load so we took 10 lbs of fuel off and ran it again. final numbers after a few runs are 286 hp with 320 tq to the rear wheels. I will be bumping the timing and heading back. Anyone have any ideas if I should chip this this or go with engine management system like "Fast'' or Uni- chip? Any suggestions would be great. Oh and the Afr numbers were around 11 to 11.5 after the fuel diet!
ok, I posted my mods and a few pics in my Garage, and then changed my signature. But just in case here are my mods.
306, Edlebrock Victor Jr's w/ 1.6 rr. Cobra intake, 24 lb inj,Adj. fuel regulator, E cam, 73mm C&L Mass air, 65mm TB,Crane hi fi 6, Taylor wires with heat boots, electric fan, 130 amp PA alt. equal length shorties, Off road H pipe, Flowmasters. 4.10's in the rear with 17x9 Cobra r's w/ 245/45 Pirrelli's.
Decent numbers, but something still seems missing. Your pressue is low if you set it at 30 with the vac line unpluged at idle...I would not go much lower than stock or near stock setting for your combo. I think you can pull 300 or better should you find the sweet spot for the F/P and timing. Good luck.
Im taking it you have an aod.....If so a good high speed torque converter will do "wonders" for your performance!!:nice: Not so much for dyno #'s but it could give you 5-7 tenths in the 1/4 with traction!!!:hail2:
Dyno
The printout says Dynomite. The guy said it gives true HP and tq readings. He mentioned that the Dynojet, and Mustang dyno's would give me a higher HP and Tq reading. We did like 6 runs, 2 Under load. He only charged me 110.00 for 4 hours of Dyno time!
DYNO'D THE VERT
jjd975 said:
You really should not need a chip to tune a na car like this. I would not get one, waste of 300+ dollars IMO.
Dumb question. Did you pull the vac line and cap it when you set fuel pressure?
WOW. 4 hours to make 6 pulls?
We took our time and let the car cool down between each run. Plus they were going over AFR with me and talking about what we could do. My fuel regulator does not have a vac port. I am going to change to a BBK one with the port. I bought the car with the one thats on there and when I saw that it didn't have it the other day I wanted to change it then but was low on cash. I was going to bump the timing a few degrees and then change the fuel reg. Hopefully that will give me a few more Ponies
