P p.exeter_bleu Founding Member Jan 6, 2002 293 0 16 El Paso,TX Dec 7, 2003 #1 Dec 7, 2003 #1 just as the title says, when i pull the brake up i wont hear a click till the damn lever is pretty high. is it the cable(s), or shoes/pads? thanks.
Asha'man Founding Member Feb 5, 2002 1,909 0 0 Denver Dec 7, 2003 #2 Dec 7, 2003 #2 Probably either the cable or the e-brake assembly itself. Mine was stretched from hauling on a frozen cable for months, had to bolt in a new handle. Ash
BlackFox5.0 Founding Member Aug 7, 2000 3,514 1 0 Massachusetts Dec 7, 2003 #3 Dec 7, 2003 #3 Maybe the cable self adjuster? It's confusing to how it wokrs, I haven't put thought into the function of it, i have mine off the car now, and the part the cable goes on is self adjusting
P p.exeter_bleu Founding Member Jan 6, 2002 293 0 16 El Paso,TX Dec 8, 2003 #4 Dec 8, 2003 #4 is it difficult to put in a new cable? how much would a shop charge to fix this? thanks.
Matt90GT Founding Member May 6, 2001 3,055 0 0 Oregon Dec 8, 2003 #5 Dec 8, 2003 #5 you need a new cable. If there is not tension, the self adjusting mechanism does not work or as you hear it "click" DUDE, call around local man! Unless you live in the same town, repair cost will differ.
P p.exeter_bleu Founding Member Jan 6, 2002 293 0 16 El Paso,TX Dec 8, 2003 #6 Dec 8, 2003 #6 cool ill just order the cable and try and a DIY job. thanks.
DTT92LX New Member Oct 28, 2003 185 1 0 Downingtown, PA Dec 8, 2003 #7 Dec 8, 2003 #7 I had the same problem. It was a frozen cable. Shop fixed it for me back then but dk the price.
