Mustang Forums at StangNet
Search
By:
By:
Advanced…
What's new
Search
By:
By:
Advanced…
More options
Toggle width
Install the app
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
E-Brake Tension reset
  • Thread starter Thread starter AIbandit
  • Start date Start date Jan 16, 2012
AIbandit
AIbandit
76
Jan 16, 2012
  • Jan 16, 2012
Where do you stick the "pin" in the E-brake handle when resetting the tension?
I'm trying to install new e-brake cables and they don't reach.
89 fox 5.0
Edit: Disregard I got it.
Thank you
dan50
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
dan50
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
78 Mach1
Parking brake cable
  • 78 Mach1
  • Apr 21, 2025
1974 - 1978 Mustang II Talk & Tech Apr 30, 2025
78 Mach1
78 Mach1
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • Dark Mode
  • Contact us
  • Terms and rules
  • Privacy policy
  • Help
  • RSS
Community platform by XenForo® © 2010-2026 XenForo Ltd. | Style by ThemeHouse
Top Bottom
Back
Forums
