E303 cam and AOD
grippper
494
i have been reading some other posts and some people say this cam will kill my power. should i install it or will i be sorry i did. right now with my setup i have if i punch it to the floor it shifts a 5,500 i was hoping this cam would get me into the red.will it kill alot of my lowend torque.
the cam will not give you rpm....5500 rpm is a good shift point...with the E cam the power is moved up into a little higher rpm...i suggest a 2800-3000 stall converter with the e-cam.....
the e-cam will kill a little bit of your low end power but you will gain in the top end.
i have the F-cam.....my car pulls like crazy above 3000 rpm
When I put the E303 cam in my car I ran slower times at the strip because I didnt have a stall so that I could get up in the power range. I would really get a 3000rpm stall converter or even 2500, either would be a good choice.
