easy rear speaker ?
  • Thread starter Thread starter skunk21
  • Start date Start date Jul 4, 2007
skunk21
1,203
Taxachusetts
Jul 4, 2007
  • Jul 4, 2007
91 hatch, bought the car w/o stereo. the door has stock speakers which I'm changing, removed the rear grilles to find no speakers just wires . my ? is I know the size and measured the depth so I don't hit the brace that is behind the panel but how does the speakers mount ??? never mounted one before so I have no idea. like I said just wires, the cars body brace, insulation thats it no bracket or anything to bolt the speaker to.
also pics of how one is mounted would be a big help. thanks.
-[White90GT]-
Kannapolis,NC
Jul 4, 2007
  • Jul 4, 2007
The rear speakers mount to the speaker grille. If you turn it over, you will see 4 holes where the screws go. All you gotta do is put your speaker on, put the speaker grille in place, screw it in, and your ready to go.
Also, when you replace the door speakers make sure you measure the depth from the door to the window track. If you buy a speaker thats to "tall", the magnet can attach to the window track and it can cause your stereo to go into "protect" mode, which is hard to fix because you have to unhook your harness, and a bunch of other mess.
If you buy a speaker and it does get to close to the window track, you can always get some longer screws and a few washers to pull it away from the track.
Hope everything goes well!
skunk21
1,203
Taxachusetts
Jul 4, 2007
  • Jul 4, 2007
thanks alot for the help my fellow white gter. wouldn't have never thought it mounted to the grille itself, this site is great, learn new stuff all the time . thanks for the door speaker tip, happy 4th .
-[White90GT]-
Kannapolis,NC
Jul 4, 2007
  • Jul 4, 2007
Back atcha man
Oh yeah, if you ever decide to get dash speakers you will have to find some that clear the air conditioning vent.
Happy 4th!
Metalcop
148
New Hampshire
Jul 4, 2007
  • Jul 4, 2007
Check out Crutchfield.com. You can punch in your car and year etc. and they will give you a list of everything that fits. Just pick speakers in your price range and you are done. Crutchfield includes wiring harnesses and master sheets, detailing teardown and installation procedures as well. I have been using them for over 12 years, for everthing car audio and electronics as a whole and have been 110% satisfied. Their prices are almost always better or the same, you just get more. Not to mention they have a technical assistance line that is fantastic. And no, I don't work for them!
skunk21
1,203
Taxachusetts
Jul 4, 2007
  • Jul 4, 2007
thats where I'm getting my stuff from, I got my system for my contour from them. they are great to deal with. I like using the harnesses they supply so I can keep my factory system to keep my svt value years down the line.
I'm not using the dash speakers for now unless I run a crossover to feed them, since I'm bypassing the factory amp.
LaserSVT
3,548
233
Jul 4, 2007
  • Jul 4, 2007
I have been an intaller for years and never found an adapter that works right for the fox stangs (scosche, metra etc.) because of the factory amp. Also any 6" speakers out will drop into the doors fine, if you want to go to 6.5 or 6.75 I would suggest cutting out the factory speaker grill and mounting it through the door panel, if you use washers to space it out you will loose your mid bass. I have MB Quat Premiums in mine mounted through the door panel and it sound killer. In the rear any 5x7 or 6x8 will fit the mounting points. 3.5's in the dash will tend to mess up your imaging. Also the factory 3.5's have a high pass cap on their side so you dont have to worry about blowing them (unless you give them more than 25 watts).Good luck and keep us posted!
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jul 4, 2007
  • Jul 4, 2007
Very good advice from everyone. I have 6 1/2" in the door, but they are a special application speaker from Pioneer. Good luck with your system.
Metalcop
148
New Hampshire
Jul 5, 2007
  • Jul 5, 2007
Yeah, ditch the factory football amplifier. Get rid of it altogether, it will free up some much necessary space behind the radio. I deleted the football and just used the factory wiring from the amps harness to wire up my speakers, worked very slick, just use a 9v batter or some other power source to figure out which wires go to which speakers (listen for static). I tried using diagrams, but there is a lot of inconsistency out there, IMO.
RUNINAGT
237
CHARLESTON S.C.
Jul 5, 2007
#10
  • Jul 5, 2007
  • #10
My Stang has all the O.E speaker in it now. (take note of mileage on car) It had the factory stereo when I got it though (which I still have), had an aftermarket deck installed with an amp and 10" sub. Still useing the O.E speakers. It sounds great IMO. Here's my delima. The back driver speaker has blown now. I would like to keep the O.E speakers in it but Ford does not make them anymore. Wanted to keep it O.E. so it plugs right back up. Now I gotta find me some replacements. Anyone have the factory 5x7 in good shape they wanna ace.
It is a 5x7 right??
R
RS200
95
Winnipeg, Manitoba, Canada
Jul 5, 2007
#11
  • Jul 5, 2007
  • #11
Alpine 5x7s work for the back..any 6.5" for the door.
89 GT Convertible Rear Speakers Quieter Than Front
  • JulianR
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 26, 2025
P
Interior and Upholstery Door Speakers- found suggestion to go component, not coaxial
  • pindude80
  • Apr 21, 2025
2K
Fox 5.0 Mustang Tech Apr 28, 2025
Mindseye007
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 24, 2025
Scott_S
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
