Edelbrock Performer
HJP0313
Jacksonville, N.C.
Hey guys I picked up an Edelbrock Performer upper and lower intake. I'm planning on running AFR165 heads and I was thinking a TFS1 cam. However, I'm not sure which size TB and MAF would be best. I'm going to have the edelbrock ported to match the heads. I'm also wondering if I should do bigger injectors and maybe a 255lph fuel pump? Thanks!
If I remember correctly they have a 70mm tb opening. As for the mas I'd go with at least a 70mm(prefer an 80) calibrated to some 24 or 30# injectors. I also recommend a 255 pump,a dyno tune and if in the budget a custom hyd roller cam instead of the tfs1. That cam is descent off the shelf selection but there are better available.
