Guero Active Member Oct 11, 2005 2,148 0 47 Aug 28, 2007 #1 Aug 28, 2007 #1 What size of bolt do i need to plug up the holes on the heads for the egr for trickflow heads???
juiced_94gt Active Member Mar 30, 2005 1,143 0 36 Southern California Aug 28, 2007 #2 Aug 28, 2007 #2 5/8 coarse
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Aug 28, 2007 #3 Aug 28, 2007 #3 Use spark plugs break the porcline off. worked for me but Thats on stock heads. Doesn't trick flow sell the smog/thermactor plugs???
Stanger007 Founding Member Sep 26, 2001 2,015 2 46 Baton Rouge, LA Aug 29, 2007 #4 Aug 29, 2007 #4 Put some locktite on the trickflow plugs if you go that way... - had them back out without it! Wes
Guero Active Member Oct 11, 2005 2,148 0 47 Aug 29, 2007 #5 Aug 29, 2007 #5 Bosko5.0 said: Use spark plugs break the porcline off. worked for me but Thats on stock heads. Doesn't trick flow sell the erg plugs??? Click to expand... mmmmm im on a budget so ill look into this lol!!!
Dino Dino Bambino 15 Year Member Jun 13, 2007 1,673 90 79 Cyprus Aug 29, 2007 #6 Aug 29, 2007 #6 Bosko5.0 said: Use spark plugs break the porcline off. worked for me but Thats on stock heads. Doesn't trick flow sell the erg plugs??? Click to expand... They're called thermactor plugs and they're for the smog pump system, not the EGR.
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Aug 29, 2007 #7 Aug 29, 2007 #7 Bulitt95 thanks for pointing that out I knew what he was talking about but typed something else.
Guero Active Member Oct 11, 2005 2,148 0 47 Aug 30, 2007 #8 Aug 30, 2007 #8 EGR is so much easier to write, and usually they know what your talking bout anyways....
Guero Active Member Oct 11, 2005 2,148 0 47 Sep 24, 2007 #9 Sep 24, 2007 #9 To answer my question...It was a 3/8 and not a 5/8....
