EGR question
  • Thread starter Thread starter Andres2882
  • Start date Start date Feb 22, 2006
A
Andres2882
316
  • Feb 22, 2006
I've read through a good many of the EGR posts but had a few specific questions. My car has no smog pump and since I'm putting a new longblock into the car, I was considering removing as much clutter as possible. Without a pump, is my EGR system working anyway? Previously i had capped off the piping that runs from the back of the heads forward. Any help would be appreciated.
vristang
4,933
101
124
Seattle
Feb 22, 2006
  • Feb 22, 2006
The egr routes through the stock lower/upper intake manifold the pipe in the back of the block is for the smog pump.
The air pump is completely separate from the EGR. EGR just adds exhaust gas to the intake mixture. The smog pump adds fresh air to the exhaust, helping the cats do their job.
I don't recommend removing the egr. There is no performance gain, and there is the possibility of drivability issues at part throttle. If you do remove the egr it would be best to disable the function in the computer, but this requires modifying the program in the computer itself.
A
Andres2882
316
  • Feb 22, 2006
OK, that helps a lot. So I can block off the back of heads and remove that pipe and still retain the EGR, that is just what I wanted to hear. Thanks.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
