  • 1994 - 1995 Specific Tech
EGR Removal?
  • Thread starter Thread starter jstang94gt
  • Start date Start date Apr 11, 2006
J
jstang94gt
  • Apr 11, 2006
Alright, while working on my car ('94 GT) this weekend, one of my friends recommended I remove the EGR and smog pump from the car to clean up the engine bay and get rid of some unnecessary weight. I was reading around and found out that there's no concensus on whether removing the EGR will help the car at all, and that it actually hurts performance in many cases, especially without a tweecer or similar tuner.
I'm just wondering if anyone has done this and had any problems, or if I should just leave it be. The engine is bone stock, only have exhaust and gears done. I'm still learning, and reading arguments back and forth makes me wanna , so any help or personal experience would be awesome. Thanks in advance.
Jason
18mustangs
533
Virginia Beach, VA
Apr 11, 2006
  • Apr 11, 2006
Jason
DON'T DO IT!!! I capped off my EGR because my BBK LT headers didn't have the EGR bung...big mistake as my car had a severe detonation problem afterwards that only stopped after I did the Fox TB converstion and ran the Fox EGR setup. There are no benefits to deleting EGR other than "cleaning up the engine bay" and you will fail an inspection if you have one in your area. If you want I can send you the scientific reasons not to delete EGR, but I think staving off the ping thing is probably good enough. You can delete it if you shut the function off inside of the computer at the same time with a tuner, but you'd still fail an inspection.
Tim
84convertablegt
589
Columbus, OH
Apr 11, 2006
  • Apr 11, 2006
also did the fox tb swap and used the foxes internal egr. cleans it up nicely. there is no reason to delete it unless like 18mustangs said, you remove it from the stock program. it is only turned on at part throttle to reduce combustion temps while more timing is added to help combat emmissions. if you just remove it, the computer will still add too much timing and you will detonate most likely. at WOT it is turned off so it wont affect anything. leave it be, or get a chip. or do the cool thing and do a fox tb swap and that will eliminate that p.i.t.a. external egr tube. i hate that thing
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 11, 2006
  • Apr 11, 2006
At WOT and idle, the EGR is inop, thus negates the performance reasons for removing it.
The smog pump runs at idle for the first 120 seconds or so, and also at part throttle, but is inop at WOT.
So, the only reason is for removing junk from the bay, and you need to rig the egr sensor so the comp thinks the egr is still there.
Scott
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Cali Members, Get in Here! - Smog issue with possible error on 2007 Shelby GT Emissions label failed due to EGR
  • saldua
  • Mar 30, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Apr 1, 2025
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
