Egr Spacer Plate
  • Thread starter Thread starter awellman
  • Start date Start date Aug 6, 2013
A
awellman
Columbus, OH
Aug 6, 2013
  • Aug 6, 2013
can i run a 65mm EGR spacer plate on my stock throttle body? and before give me the run around about doing other mods first, im going to but im going to order the EGR spacer first because money is tight right now.
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2013
  • Aug 6, 2013
you could but you wont see anything from it.
save your money for an explorer top end or you can make your own knock off Anderson Power Pipe which will you give you more benefit than an egr spacer.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 6, 2013
  • Aug 6, 2013
Nice first post. Yeah sounds like a great idea. I would in fact run a 90mm spacer. That should add at least 50 hp.
I'm going to have three Doritos tacos for lunch btw.
Admin Dude
Jan 4, 1985
43,548
21,717
234
Box behind Walmart
Aug 6, 2013
  • Aug 6, 2013
Not sure what the reason is for purchasing the 65mm spacer but as mentioned above, you will see ZERO gain from it. If it's a freebie or something, just set it aside until you have the throttle body to go with it.
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2013
  • Aug 6, 2013
polish it and hang it from a chain around your neck. represent yo
Admin Dude
Jan 4, 1985
43,548
21,717
234
Box behind Walmart
Aug 6, 2013
  • Aug 6, 2013
uradork
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2013
  • Aug 6, 2013
^uraweenur
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
Engine EGR spacer for explorer 65mm TB?
  • 91GTstroked
  • Dec 31, 2024
Fox 5.0 Mustang Tech Dec 31, 2024
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
