Hey guys, how is it going?
I've bought one Mustang 1967 Fastback without engine and trans. I've already bought the eleanor fiberglass kit, and the 302 block (not aftermarket)
I live in Brazil, and here the performance parts are a quite expensive!
I will be in USA in november, so I will buy a bunch of parts in america.
Here is what I'm thinking to buy in america:
Cylinder Heads
Carburetor / Fuel Delivery System
Ignition System
Camshaft
Nitrous Oxide System WET (100 - 200hp shot)
Intake Manifold
Main Stud Support
Application of the project: Street (in working days) / Race (for weekends) heheh
In Brazil its very easy to use Ethanol (I think that more than 90% of the gas stations sells it), here Ethanol is cheaper than gas, and running on Ethanol we have more horsepower.
So if I use Ethanol or E85, I will have to chose an specific kind of carb, the same with the stroker kit (piston type), once that ethanol has a different compression ratio of the Ethanol.
I've saw these parts and like them, check it out:
Airflow Research 1452 - AFR 205cc SBF Outlaw Race Heads
( Airflow Research 1452 - AFR 205cc SBF Outlaw Race Heads - Overview - SummitRacing.com )
Probe Industries PRO STREET Engine Kit - Ford 347 Dome Top +9.0cc
( 10480-PS-F347 - Ford 347 Dome Top +9.0cc Pro Street Engine Kit )
I would like to ask you guys some help to build this engine.
I want to reach something between 300 - 400 hp (without nitrous)
Which parts do you guys recommend?
Awaiting for a favorable reply!
Many thanks and best regards,
Lucas Marson
Cylinder Heads
Ignition System
Camshaft
Intake Manifold
Main Stud Support
Lucas Marson
