Electric fan doesent work after motor swap!
tamadrummer88
599
79
39
Aloha State
Ok, so i purchased a 98 GT with a blown motor, and i replaced the motor with a motor from a 96 GT. I used the 96 motor harness and the 96 PDC harness. only thing i didnt use was the CCRM and wiring harness from the 96 along with the ECU. I used the 98 ECU, and the car started right up. only thing is, the fan never engaged. So i talked with a friend that was highly knowledgeable with stangs, and he said the ECU and CCRM is what controls the fan. So i changed the ECU and installed the 96, only now the car wont start cause i have the 98 key and the PATS is activated. Im getting the spare key from my friend tomorrow from the 96 GT, hopefully that should start right up. If the fan still doesent engage, does that mean that i have to change the CCRM and everything?
The solution is quite simple. You probably should have kept the 98 wire harness intact and just installed the 96 motor. There are some differences between the 96 and 98 cooling systems. The 98 has a better cooling system (higher CFM fan, bigger AC condensor, bigger radiator, improved fan solenoid, etc.) than the 96. Why didn't you just install a newer PI motor for the same hassle? I would replace all the 98 wiring harness back in the car.
I got it to work! Just changed the coolant temp sensors from the 98 motor.
