Electric Fan Wiring Help
bison
25
Southern CA
Hello all. l have a Taurus 3.8 two speed electric fan that lm unsure of how to wire. l can wire with one speed ( max ) and relay no problem as l have done so many times in the past but would really like to wire it up with a 3 position switch ( off, low, max ) to utilize the fans two speeds. After reading many post's l am also aware of the general opinion of using a automatic fan controller switch. Many years ago l also was a firm believer in this. Until my controler switch failed ( Hayden ) unbeknownst to me on a 95 degree summer day and by the time l had realized it l had already overheated my engine and suffered the resulting damage. Will never trust a automatic switch again. Sooo, back on subject, can anyone direct me on how to wire 2 spd fan w/a switch? Do l need a special relay? A special switch? Any help will be appreciated. Thanks!
So you don't want a controller but rather to only have the fan controlled by a switch for each speed?
Just from the hip....
I think you would need to source a 3 selection switch. I would run a relay for each speed. Each position on the switch would trigger a different relay for a different speed. Or, you could run two seperate switches.
I used a Painless wiring temp switch that mounted in the thermostat housing. It closes the circuit when it reaches a certain temp and flips both my relays. I also wired up an override switch so I can run it whenever I like.
Joe
I would use a the three position toggle you speak of, and use the grounds on two relays with that switch. That way when you flick it on high you will kick the relay to turn on and the fan will go. and you won't be running a ton of voltage through the switch just completing the ground. And wire up a another relay setup for low speed. Use the correct wire and fusing for the amps it draws to start the fan.
I would save my engine and my money and buy a DC Control unit and be done with it.
If you don't have a high current alternator, you can forget about using the fan. The stock 65 amp alternator on 86-93 Mustangs isn't big enough to run the fan and the rest of the car. If you have a 94 or later Mustang, the stock 3g alternator should be fine if it is working correctly.
Switching a fan on and off manually is a bad idea. Too many guys have been distracted (hot girl kissing on their neck, too much to drink, dog tired and not thinking clearly) and cooked things because they forgot to flip the switch. An equal number have forgotten to turn the switch off for the same reasons and run down their battery.
The best fan controller available today is a DC Control unit. www.dccontrol.com. Cost is about $???. Be prepared to wait 4 weeks or more to receive your controller once you have sent in your payment. The controllers are custom made in small lots and lead times can stretch out.
Next best is a SPAL controller - $70-$120 See http://www.spalusa.com/store/Main.aspx?html=pwmv3. eBay will have the controllers for a bargain price: do a Google search and see what you find.
Do not use a simple on/off switch without using a relay. The current load can burn up the typical cheap automotive switch very quickly. The fan draws 30+amps and you need to use #10 wire on the fan power and ground wiring.
If you are good with electrical stuff (90% of the people here aren't), build your own controller. The numbers on the diagram (#86, #87, etc) refer to the numbers on the bottom of a typical automotive relay.
attachment.php
Note that the temp sensor in the diagram needs to match the thermostat in your engine. The preferred arrangement is to have it open about 5 degrees above the thermostat.
To allow the ignition switch to control the fan so that it does not run when the ignition is off, connect the relay contact #86 to the red/green wire on the ignition coil or to the red/yellow wire on the coolant level sensor.
If you are an experienced electronics tech or electrical engineer, email me and I will send you the prototype drawings of a fan controller that is similar in function to the DC Control unit. It is a build it, troubleshoot it yourself item. I will not build or troubleshoot units, so it is not suitable for anyone who isn't really good with electronics.
Alternate placement for a temp gauge sender or temp switch/temp sensor for an electric fan. Use the heater feed that comes off the intake manifold. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. Be sure to use the same water feed line as the ECT sensor. That way you will get the most accurate temp readings.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
attachment.php
