I am in the process of building a new 331 for my car. I will continue to use my blower on the car so I need a good cooling system. I am currently running a 190 degree t-stat and notice the car runs between 190-210 depending on outside temp. I was wondering is you get any better cooling with an electric water pump or if it would be a waste of money. I will change the t-stat to a 180 degree unit. I have a northern Aluminum radiator with a 3000 cfm Zirgo fan with my current setup.
Thanks for the input guys!
(check our builds and R&P, there are some similarities) There's some uncertainty as to whether my 30" rad will fit, but it's just barely enough for the low-profile flex-a-lite 210 fan to have a full seal against the full width of the core. I can show you pics if you want. I'm getting some feedback over on vintage-mustang that that rad doesn't sit between the frame rails and I might have hood clearance issues so it looks like I may have not done enough measuring, but I think I can make it work.
