I have everything removed from under the hood. I am only running the alternator and water pump. The trick with this setup is to take off the idler/tension pulley. Grind off the little notch at the back and then put the belt back on. Once it is on, use a prybar to tighten the belt in the OPPOSITE direction it used to go and tighten the bolt down. I have run the car like this for 5 years! I also just took the power steering off and caped off the hydraulic lines to the stock power steering rack. After a few pulled muscles you will be alright. The pic from jkstang78 shows this exact setup. I can stand in my engine bay and work on the motor. I can put long tubes on in 10 minutes!! No lie! I have also taken the dash apart and taken out the heater core and anything else that is not needed (ie radio). The car weighs in at 2750 with iron Windsor Sr. heads! The weight reduction was the first thing I did and the car ran 13.5 @ 100 with just gears, slicks, pulllies, and exhaust. And that was granny shifting the thing!!
