Engine build specs
  • Thread starter Thread starter TruckeeFastback
  • Start date Start date May 22, 2007
T
TruckeeFastback
18
Lake Tahoe, CA
May 22, 2007
  • May 22, 2007
I'm ready to spend about 6k or so on motor and trans for my 68 Fastback. It's got a tired old 302 and a TMX from a truck in it now.
I want to keep it 302 block and add a T5. Hopefully I can afford 400hp, if not 300-350 is ok. It will be a weekend street machine.
From what I can tell, a roller cam 302 and a rebuild with AFR heads and moderate internals should do it.
Can anyone help me spec this thing? I've already got a 2.5" exhaust system for it, AirGap intake, Hedman shortys.
What should I be looking at for pistons, cam and heads?
Thanks
65fastbackresto
1,229
AR
May 22, 2007
  • May 22, 2007
Prices
I`m in the process of doing the same thing to my 302.
Eagle rotating assembly 331 cubic inch for about $1100
AFR 165`s are about $1350
68RustBucket
119
Linwood, NJ
May 23, 2007
  • May 23, 2007
I'd go with the AFR165 heads if you can afford them. I have a similar build coming up, except it's a 289 instead of a 302.
AFR165 heads
Comp Cams 282s cam
KB hypereutectic flat top pistons
It'll be a real screamer, perfect for weekend cruises
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
