Engine Mounts
rdubb17
27
For the people who have put the engine / tranny combo together at once ever ran into the problem of getting the "nub" to fit on the driver side mount? I was playing with it all day and I just couldn't get that nub to fall into the K-member. It was if I had to lift the transmission higer than it would allow or push the engine back a 1/4 inch and I just couldn't do it. It was pretty frustrating. I believe the mounts are some sort of stock replacements from a local autostore. I'm thinking about tossing them and picking up a set of Energy Suspension Urethane ones. I'm looking at the picture at the following link:
http://www.mustangsunlimited.com/itemdy00.asp?T1=41124G+01
Does anyone know if these have those nubs or not? If I ground down the nubs, does anyone think it will negatively effect any engine movements within the bay?
i would stay away from the urethane mounts. especially the tranny mount. the vibration is horrible. as for the mount dropping in. i had a hard time as well but eventually got it to drop in. the urethane mounts have those nubs also. i dont think its a good idea to grind them down.
I have done this twice and have no advice to give but... when you are at your wits end and a torque wrench is flying through the air at the neighbor's cat the mount will somehow, miraculously, pop into place.
I didn't change the tranny mount, but I did have to get new motor mounts when I did my engine swap. My stock ones were in BAD shape.
http://cgi.ebay.com/ebaymotors/89-9...ryZ50454QQihZ016QQitemZ260186026507QQtcZphoto
Pretty happy with them and they are quite a bit cheaper than the real things. But it seems you might have better luck with the tranny/engine separated. I have a heavy arse AODE, so I separated them when I installed mine.
