Some of you may know my story, but for whoever doesn't:
college student with his first Fox, an '88LX. I've done minor work, front A arms, front lowering springs, steering rack, some engine brackets, so just minor stuff.
I have struts, shocks, CC plates, a Borla exhaust, (and need to find new headers) that I will be putting in within the next month.
I have a new clutch that needs to be put in soon as well.
I have two questions, dealing with some direction decisions and I would like some opinions.
After my suspension and exhaust is finished I will turn to transmission and engine work.
1.) I am thinking of having someone rebuild my trans for me, unless it really is as easy as I have read to pull the trans and rebuild it.....
Put the new clutch in, and replace the typical trans part, throw out bearing, etc etc
I also would like it rebuilt to handle power, so forged internals?
My plan is to not have to worry about my trans when I upgrade the motor
I'm not sure what my engine power limits are, but probably upwards of 400hp, but that could change
Now my current thought in regards to motor work is this:
Currently this car is my DD, so I will do only quick bolt on mods for now...
To me this means a MAF conversion, throttle body, CAI, and intake manifolds, U/D pulleys and that's about all I can come up with right now.
In a little under 2 years I'll be graduating from College and plan to get a different DD and then make my Fox into less of a DD and put more power into it.
2.) I'm thinking of buying a second motor and put it on a stand. Then slowly take it apart and clean it up real nice. Maybe bore it out a bit and start replacing pretty much everything. Then I'd focus on putting power into that motor while still being able to drive the car.
Does this seem like a decent plan? if So I'd be looking into getting that second motor over the summer and start taking it apart and learning and cleaning. But not buy anything for it until my DD has the basics done to it's motor.
Just a bunch of questions. What did you guys do? etc etc
(I'm bored at work...so I wrote this up)
