I have a strange problem with my car, this has been going on for about 6 months, but only happens after driving the car for long distance (over 250 miles). Basicly after driving a long distance on a highway trip everything will seem fine at cruising speed, but the car has no power to pass, if I try to take off hard from a dead stop the car lurches and surges HARD. In extreme cases I can drop it into neutral stand on the gas and the rpms will not go over 3200, they will climb ok up to about 3200 then hang, if I keep my foot on the floor a couple of seconds later the car will start making an odd sound (running rich/lean? no pinging sort of sputering though) the rpms will slowly fall to about 3000 then climb back towards 3200. If I stop for gas or otherwise let the car cool down when on a long trip the problem goes away for a bit, but relativley quickly returns once I have driven a while. No codes are being tripped even when I stand on the gas in neutral (I have not dared do that for more than a few seconds though for fear of doing real damage) This happens at both partial and WOT, in case that helps I know the computer acts different and uses diffent inputs for each. Could this be a fuel pump issue? I know in the cooler months simply stopping 5 minutes to fill up the gas tank would make it go away for a good bit(the gas was much colder then too).
thanks for any help you can give my mods are in my sig.
Ike
Ike
