My 306 in the GT only has a couple thousand miles on it, but it has a bad ring in cyclinder #5 due to the un-tuned supercharger combo it had when I bought it. The s/c is gone and I just want to get the thing freshened up w/ new rings and gaskets to stop the leaking gaskets too.
I've been looking at gasket sets, and re-ring kits at summitracing.com and have found this kit:
http://store.summitracing.com/partdetail.asp?part=FEM%2D205653M%2D300&view=1&N=150
Are the rings included in that set good rings? They only sell for like $34.95 if you buy them alone. Do I need expensive rings or will those be good enough for a mild 300 hp combo?
Additionally, should I have the internals balanced? I don't plan to rev crazy high and the car won't see much track time. I don't plan to get the heads milled either because they were just cleaned up and inspected when I changed head gaskets about 300 miles ago. I want to sell it when I get it fixed, but I'm sure I won't be able to let it go. I need to get it fixed, but I'm on a budget too.
Also, the damper wobbles....should I buy a new stock damper or is that due to the crank?
