just ordered Flashark headers as mine didn't fit. Supposedly they're equal length and fit the gt40p. Coming in from China for $148
Fit perfect. Pretty happy for the price. We'll see how they sound
Thank you for the description. That was perfect. I got it done and found out why those 2 bolts were loose and unusedI did mine a few months(?) ago, goes from the solenoid down and over to the engine, the hanger with the twist in it should bolt to a boss on the timing cover on that side, comes around the front of the oil pan and that hanger will bolt to the side of the engine, I ran mine between the engine mount and the block back to the starter.
I'll try to get a pick but it's kinda crowded around there.
just spent $50 on antifreeze. Here's hoping I don't need to tear downI start mine of 50/50 mix of water and antifreeze. I think some suggest water in case they have a problem and have to tear it back down.
If so I recommend draining it right after the start up and adding antifreeze... I was surprised at how quickly mine rusted up......I start mine of 50/50 mix of water and antifreeze. I think some suggest water in case they have a problem and have to tear it back down.
yea, I wanted to run water, but I don't think I could fully drain it through the radiator. And if I can't, then I risk a cracked block since I'm in MinnesotaIf so I recommend draining it right after the start up and adding antifreeze... I was surprised at how quickly mine rusted up......
Any water that is left in the block will mix with as the engine runs, keep track of the amount of water you put in and then when you drain it, I bet it won't be a half gallon, prolly less, left in the block. Adjust with straight antifreeze then fill with the mix.yea, I wanted to run water, but I don't think I could fully drain it through the radiator. And if I can't, then I risk a cracked block since I'm in Minnesota
Who ME??man you make a good point. Now I need to run to the store to get distilled water. Thanks!
Who ME??
Some people are just easily impressed![]()
Yeah, she calmed down as soon as he paid herIt's the same speech he gave the night we struggled with the hookah. It turned out alright.![]()
She never said she was allergic to antifreezeYeah, she calmed down as soon as he paid her![]()
