Engine shaking
  • Thread starter Thread starter wruddy
  • Start date Start date Apr 17, 2005
W
wruddy
71
Oxford, PA
Apr 17, 2005
  • Apr 17, 2005
long story - short - 94 gt stock
Engine shake came on quick.
Done so far....
*Changed fuel filter, plugs, wires, cap, rotor, pvc valve
*clean MAF
*clean K&N air filter
*looked and did not find any vacumn line leaks
*Hook up two cans injector cleaner to fuel rails and ran it thru - improved 80%
*ran two cans injector thru two tanks of gas - no improvement.
*pulled injectors, soaked them in cleaner, replaced one that was not allowing fuel through. Car ran the best it has ever run with no engine shake and lots of new found pickup for 30 miles. then shake came back slowly until it is now shaking so bad I am afraid to drive it.
what next - clean fuel tank, blow out fuel lines, reclean injectors?
Any ideas or suggestions welcome.
droptopford 5 0
427
May 5, 2005
  • May 5, 2005
Done so far....
*clean MAF
what kind of shake is it, rpm specific, at idle, all rpms, with the clutch in or out... whatsup?
cavscout371
277
  • May 5, 2005
has the balancer ever been replaced?
Venom351R
4,548
41
98
MAINE
May 6, 2005
  • May 6, 2005
I bet your harmonic ballancer is shot.
W
wruddy
71
Oxford, PA
May 6, 2005
  • May 6, 2005
Fixed it
The whole engine and trans would shake like hell - all rpms - for a day to two and then stop. heres why -
It was the harmonic balancer. The hard rubber weight inside the metal cover was loose and spinning. Sometimes when I shut the car offf and then back on the rubber part would stop at the right spot, be in balance, and the car would not shake anymore. Drove me me nuts trying to find this one. Thanks for your help!
Venom351R
4,548
41
98
MAINE
May 6, 2005
  • May 6, 2005
what are you going to get for a new ballancer?
W
wruddy
71
Oxford, PA
May 6, 2005
  • May 6, 2005
balancer
The guy who did it for me (brother-in-laws friend) who is a mechanic put a stock balancer back on there from Ford. The car has 170,000 on it now and runs great being 99% stock. I want to keep it that way until the engine goes and then I will build a bigger engine from the block up. Just trying to keep the car in good shape so I can have a fun winter tear down and rebuild someday. With all the tuneup and tweaking done trying to fix this problem the car jumps when I touch the pedal now. It never used to do that.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
