engine
  • Thread starter Thread starter jlangholzj
  • Start date Start date Dec 6, 2006
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Dec 6, 2006
  • Dec 6, 2006
guys, first of all i would like to thank all of you out there. you've really helped me with all of my questions.
http://market.autopartsfair.com/ford-car_engines/catalog-item-5062.html
check this link out.i was thinking about rebuilding a 289 but im wondering if this wouldn't be cheaper? im assuming it would bolt right up to a 4spd manual that i got with the car.
currently its got a 6cyl and a 3spd and i want to upgrade.
also im wondering if anyone knows where i can get a complete rear end, preferably something like a 9" with posi in 5bolt. either that or the next size smaller wich is a ...?
iskwezm
4,159
20
79
Rowland Heights,California
Dec 6, 2006
  • Dec 6, 2006
dont forget anout the accessories and intake/carb,exhaust,starter etc. It all adds up real quick.
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Dec 6, 2006
  • Dec 6, 2006
i have all the parts from the old 289 plus a 6 cyl including the accesories!
BullittStangV8
1,104
NJ
Dec 6, 2006
  • Dec 6, 2006
It def adds up REAL quick.
Like: distributor, ignition, clutch, flywheel, itntake, carb, fuil pump, water pump, radiator, headers, oilpan/pump, valve covers, tranny bellhousing...
When I blew my 289, I thought that replacing the motor with a performance motor wouldnt be THAT big of a burden money wise...boy was I wrong! Getting all the right parts together is time consuming, and it gets expensive. I hope it'll be worth it for me when it turns over the first time.
BullittStangV8
1,104
NJ
Dec 6, 2006
  • Dec 6, 2006
well then nvm. that last post.
LMan
1,246
Mom's basement
Dec 6, 2006
  • Dec 6, 2006
what happened to the '6 to V8' FAQs?
D
danny clemens
728
  • Dec 6, 2006
The 57 thru 59 Fords are a good swap for a 9". Some others will work also. An 8" would work if you're not building too radical. They should be cheaper than a 9" also.
Check the sticky for rear ends for all sizes.
  • dan50
  • Jul 18, 2026
dan50
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
