English Please
94coupe
138
Calgary ab
code 565 and 332 insufficient egr flow and canister purge solenoid circuit fault??????
how do I fix these......I wanna run cylinder balance test but cant till I fix these problems?
thanks in advance cam....
By replacing the purge canister solenoid. For the egr ensure all the related vacuum lines are intact (not broken, cracked or split). The oem where hard plastic and are likely cracked or broken by now. I would just change the plastic lines with vacuum tubing of the correct size. This stuff is sold by the foot.
