Build Thread Enola- Finishing touches
  • Thread starter Thread starter a91what
  • Start date Start date May 31, 2015
  • Tags Tags
    393 4r70w megasquirt ms3 ms3pro turbo watermeth injection
  • 87
  • 88
  • 89
  • 90
  • 91
  • 239
First Prev 89 of 239 Next Last
General karthief
Mod Dude
Aug 25, 2016
28,029
10,654
213
polk county florida
Oct 1, 2017
#1,761
  • Oct 1, 2017
  • #1,761
are you going to do the y and duel t bodys like we talked about?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2017
#1,762
  • Oct 1, 2017
  • #1,762
If I can find another 65mm throttle body I may do it. Would be different and I like that, but they must match. I would need an explorer throttle body so they are the same.
General karthief
Mod Dude
Aug 25, 2016
28,029
10,654
213
polk county florida
Oct 1, 2017
#1,763
  • Oct 1, 2017
  • #1,763
What about a pair of mustang t bodies? They are not 65mm are they
Thinking about it I may know where another explorer t body is.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 1, 2017
#1,764
  • Oct 1, 2017
  • #1,764
Even 2 stock 55mm TB would work..... makes for a very large effective opening. I even have a 65mm and 75mm I'd be willing to trade..
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 2, 2017
#1,765
  • Oct 2, 2017
  • #1,765
Come one come all to the give me your opinion box. Today we have multiple options in the supercharger inlet line up.
Option1. LS1 throttle body
Pro: cheap fits the bill for size at 92mm and will bolt to the elbow
Con: requires throttle cable change out and rewiring of the engine harness. The hood will need to be shimmer for clearance.
Option 2. Build a manifold for a single large Ford TB.
Pro: works with current linkage
Con: must fab a new manifold and very costly.
Option 3. Build a wild manifold for 2 65mm TB.
Pro: will look crazy, TB are cheap and easy to find at jy.
Con: must build a manifold and linkage.
Option 4. 03Cobra TB and plenum
Pro: large TB, cost is relatively low as of today has provision for iac
Con: must make adapter manifold and adapt linkage.
Issue as of today is that the linkage in the current configuration will hit the blower case. I do not want to clearance it for obvious reasons.
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Oct 2, 2017
#1,766
  • Oct 2, 2017
  • #1,766
...and figure out how you're going to split the TPS signals and whether these will run through a single or dual MAFs (or SD?).
This option just sounds like a pain in the balls.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 2, 2017
#1,767
  • Oct 2, 2017
  • #1,767
One tps signal needed, and SD. The only thing that would become problematic would be tuning the accel enrichment. I already have a linkage made up from the m90 setup I would just have to shorten it. (Lokar cable)
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Oct 2, 2017
#1,768
  • Oct 2, 2017
  • #1,768
Unless you're going to see it with the hood closed, nobody cares.
Now, back to the skull idea. You could make the jaw open when you step on the gas.
Reactions: krazedstang, General karthief and RaggedGT
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 2, 2017
#1,769
  • Oct 2, 2017
  • #1,769
I would totally do the skull if someone can find/make/give the thing to me.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Oct 2, 2017
#1,770
  • Oct 2, 2017
  • #1,770
can you try just flipping your current one upside down? if that works, a fox-style 90mm will bolt right one. theres also kits to remote mount the iac or convert to a gm style if that also gets in the way.
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Oct 2, 2017
#1,771
  • Oct 2, 2017
  • #1,771
Only 1 left in stock. Order soon!
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 2, 2017
#1,772
  • Oct 2, 2017
  • #1,772
I tried turning the TB all kinds of different ways, no matter what I did the clearance just wasn't there. now a remote mount iac may allow it to work with some creative linkage reworking. The elbow is what is close to the hood, I can flex the hood and touch the elbow.... no bueno
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 2, 2017
#1,773
  • Oct 2, 2017
  • #1,773
you may have something there
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Oct 2, 2017
#1,774
  • Oct 2, 2017
  • #1,774
Amazon product ASIN B00KEVKQIGView: https://www.amazon.com/Steam-Skull-Leather-Goggles-Figurine/dp/B00KEVKQIG/ref=sr_1_203?ie=UTF8&qid=1506988243&sr=8-203&keywords=skull+statues+and+figurines
There are others:
https://www.amazon.com/s/ref=sr_pg_...urines&ie=UTF8&qid=1506988291&tag=stangnet-20
RaggedGT
Mod Dude
Jul 20, 2014
4,751
3,206
203
Taylorsville ky
Oct 2, 2017
#1,775
  • Oct 2, 2017
  • #1,775
I vote for Option 1 or Option 4. Imo in this case, simple might be better
hoopty5.0
mechanicus terribilis
7,809
6,961
214
SW Houston
Oct 3, 2017
#1,776
  • Oct 3, 2017
  • #1,776
K.I.S.S.
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Oct 3, 2017
#1,777
  • Oct 3, 2017
  • #1,777
hoopty5.0 said:
K.I.S.S.
Excellent idea!
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 4, 2017
#1,778
  • Oct 4, 2017
  • #1,778
The easy way or kiss sounds a lot like something "other" people would do. Since im not everyone else I prefer the non bellybutton way.
BEHOLD!
Reactions: Davedacarpainter
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Oct 4, 2017
#1,779
  • Oct 4, 2017
  • #1,779
BEHOLD!
Will a truck dual throttle body work?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 4, 2017
#1,780
  • Oct 4, 2017
  • #1,780
Probably if it flows at least 1k cfm.....
I know 2 65mm explorer throttle bodies honed out will be more than adequate.
  • 87
  • 88
  • 89
  • 90
  • 91
  • 239
T
TJ's Eaton M90 Build-Up Thread
  • tjh566
  • Jan 8, 2007
  • 1994 - 1995 Specific Tech
  • 3 4 5
30K
1994 - 1995 Specific Tech Oct 15, 2007
RAD
R
