Estimated Rear Wheel numbers....
Black93SVT
363
North Andover MA
Ok with flowtech shorties offroad H and 2 chamber flows everything else stock i put down 215rwhp and 282rwtq. Now heres the list of mods.....
Scorpion 1.7 RR's
Accufab 65 mm TB and Spacer
TFS Street Heat Intake
75mm Pro-m
Underdrive pulley's
BBK Long tubes and Short H pipe
BBK Cold Air
With just exhuast I ran whats in my sig... any ideas what i'll run with the above mods, 3.73's and a set of BFG Drag Radials?
probably about 245hp and 300 tq. I would guess that the car should go 13.4-13.6 if you can drive!!!! ITS ALL IN THE LAUNCH! You need to get your sixty foot times down to at least a 1.8!!!!!! GOOD LUCK!!!!
what do yo guys think an e-303 or trickflow stage one would be worth for a little bit more power.... my goal is around 260-265. Could i still run the 1.72's with one of those cams or would i have some piston to valve clearance problems?
