Everyone do yourself a favor
  • Thread starter Thread starter 1986LX2002
  • Start date Start date Dec 15, 2004
First Prev 2 of 2
nito88stang
2,012
Fullerton, California
Dec 15, 2004
#21
  • Dec 15, 2004
  • #21
viper alarm and two kill switches here. One for the fuel and another for electrical, if they want mine they'll have to tow it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2004
#22
  • Dec 15, 2004
  • #22
StangCrazy302Gt said:
where is the best place 2 add a kill swick..and whats the best way 2 install 1??
On 86- 91 cars the fuel pump relay is under the seat, 92 and later cars, the fuel pump relay is under the Mass air duct on the passenger fender well.
Note that the wire colors changed in 1991, so there are two different descriptions.
86-90 model cars:
Cut the red/black wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the red/black wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced red/black wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model wiring diagrams.
91-93 model cars:
Cut the Lt Blue/Orange wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the Lt Blue/Orange wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced Lt Blue/Orange wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model wiring diagrams.
F
fox3streetracer
195
ocala,fl
Dec 15, 2004
#23
  • Dec 15, 2004
  • #23
well,a car alarm is a good deterent.most theifs dont want the hassle when they see that led flashing on the dash and know you have one.my alarm is so hidden,i prob have miles of wire going to it.i would mount the alarm anywhere but in the dash.thats where everyone mounts them due to ease.truth of the matter is,if someone wants your car bad enough,everything is useless.but i would make it hard as you can for them.
bobcatv8
141
Ocala,FL
Dec 15, 2004
#24
  • Dec 15, 2004
  • #24
No-Buck anti-theft tricks.
Pull wire from starter relay or pull rotor from dist. cap and put it in your pocket. Not convienent but no thief will drive away with your 5.0!
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Dec 15, 2004
#25
  • Dec 15, 2004
  • #25
Really, the flashing light is the only real deterent. A thief is going to rip the gauges out of my car before he's going to bother stealing it... Either way it just plain sucks.
My alarm is more to unlock the doors...
Jamie
1986LX2002
317
#26
  • Dec 16, 2004
  • #26
Yeah those who dont have any anti theft or starter kill on their stangs are just asking for trouble. I was never worried about it I live in phx az and who would want a stock 1986GT??? Well it was obvious someone wanted one "good taste at least"
PNY PWR
522
Wichita, KS
Dec 16, 2004
#27
  • Dec 16, 2004
  • #27
Sorry man, people need leave others stuff alone. Shouldn't be too hard of a fix once you get the parts.
Good luck
Procharger95
222
Montgomery and Decatur, AL
Dec 16, 2004
#28
  • Dec 16, 2004
  • #28
Someone did the same type of damage to my 87 Mustang
My 87 isn't in the best of shape so after seeing what they did to your ignition and how it is almost identical to mine I'm wondering if it wasn't just a nationwide ploy of ricer jealousy against the superior Mustang crowd!
StangCrazy302Gt
282
New Jerzy
Dec 16, 2004
#29
  • Dec 16, 2004
  • #29
jrichker...& bowtiekiller thank u will have 2 try that when i get time during work and can use the garage.and what diagram do i pik on the autozone page there r a few???
1986LX2002
317
#30
  • Dec 16, 2004
  • #30
Well I started pulling the rest of the column apart I need a whole new tumbler housing. How do you get the tilt steering mechanism off the column though? It semi rotates on two out pin with machine screw thread and it has to slots to pull it straight out once you get those out i guess?? I looked in my haynes manual "crappy azz book ever made" and it had nothing other how to replace the tumbler and module. I was guessing so i found two screw with the same thread type and put them and tried to pull them out but no luck and i dont want to mess it up because i'm going to have to goto a recycle yard and get the housing and i have to know how to do this. Here are some pics of what i'm talking about.
1986LX2002
317
#31
  • Dec 16, 2004
  • #31
Few more pics of the column and my car which is undriveable right now.
PNY PWR
522
Wichita, KS
Dec 16, 2004
#32
  • Dec 16, 2004
  • #32
Crap, I withdraw my prior easy statement. I have a parts store Chilton manual, it sucks pretty bad too.
So htere's somne type of pin on one side and a bolt on the other?
PNY PWR
522
Wichita, KS
Dec 16, 2004
#33
  • Dec 16, 2004
  • #33
Think it would be easier to swap out the whole steering column?
slo65
448
Southern California
Dec 16, 2004
#34
  • Dec 16, 2004
  • #34
i'm sorry to hear about your car, my 65 was messed with a couple of times, more like vandalism though, damn jealous people.... as far as the 5.0 i got a little cheap dual stage alarm, i didnt set it too sensative so a passing car wont set it off, its only been set off once actually and that was by my dad, it has a big flashing led light by the left side of the column. so it has done the trick if i'm really worried about where i parked it i take the fuel pump relay with me, the car will start but it'll die about 5 seconds later
1986LX2002
317
#35
  • Dec 16, 2004
  • #35
Yeah I could get a new column but it was acutally easy to take apart, i just need that tilt system off. Anyone have an idea?
First Prev 2 of 2
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
T
Nissan V8 Swapping a 1996 SN95 Mustang. Have I lost my mind?
  • TJ Rebuild
  • Feb 14, 2021
  • Other Auto Tech
5K
Other Auto Tech Mar 3, 2021
LILCBRA
Anyone Recognize This 96 Gt From Near Mechanicsburg Md??
  • Cobra42898
  • Jun 23, 2015
  • Regional Forums and Event Information
Regional Forums and Event Information Jun 23, 2015
Cobra42898
A
Help understanding relationship between flywheel and engine vibration
  • AwPhooey
  • Dec 20, 2012
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Jan 3, 2013
AwPhooey
A
