Exhaust Smell
  • Thread starter Thread starter billison
  • Start date Start date Dec 12, 2016
  • 3
  • 4
  • 5
1 of 5 Next Last
billison
I like tinted tail
2,607
1,094
184
stl
Dec 12, 2016
  • Dec 12, 2016
Ok. 88 5.0
Long tubes, no cats, into flows with tails. No smog pump, egr still in place.
Trying to cut down the exhaust smell. It burns my eyes if I run it at all with the garage door shut. As simple as welding in some cats? Do I need to worry about the o2 sensors in relation to the cats?
Simi related, charcoal canister is missing, but I have the plug and solinoid , I know one side goes to the intake, is the other side a soft line to the tank or what am I looking for?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Dec 12, 2016
  • Dec 12, 2016
Add cats. Should cut down on the smell a lot. You'll need a smog pump if you actually need to pass the sniffer (which I doubt) otherwise without it, it won't be as efficient.
As for charcoal canister. One line to front of manifold, another semi-hard line runs to the gas tank
billison
I like tinted tail
2,607
1,094
184
stl
Dec 12, 2016
  • Dec 12, 2016
No smog, just tired of smelling like exhaust and the wife hates it.
After the 02 sensor is fine right?
And where would the semi hard line be located? Nothing was hooked up. Passenger side area I assume .
hoopty5.0
mechanicus terribilis
7,848
6,992
214
SW Houston
Dec 12, 2016
  • Dec 12, 2016
Yes after, and get Hi-flow cats.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 12, 2016
  • Dec 12, 2016
Looking at these. Should be a simple job. ( famous last words )
https://lmr.com/item/FLO-2230125K/Mustang-Flowmaster-25-Mini-Catalytic-Converters
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Dec 12, 2016
  • Dec 12, 2016
I have no cats, sorry jrichker, full tails on 89 gt and no I didn't slice a hole in the bumper cover, never smell anything even with the windows up sit'n at a light. Its them pipes terminating under the car.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 12, 2016
  • Dec 12, 2016
I keep reading this I just can't figure out where you're trying to say
Reactions: Davedacarpainter
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Dec 12, 2016
  • Dec 12, 2016
billison said:
I keep reading this I just can't figure out where you're trying to say[/QUOTE
My dyslexia kicked in, I read you DIDN'T have tail pipes, after reading it again I'm reading you DO have tail pipes, sorry.
My car looks like crap but doesn't stink, go figure.
JD1964
there is enough sticking out to grab on to
3,637
1,658
194
Maryland
Dec 12, 2016
  • Dec 12, 2016
If it's burning your eyes, I'd say the A/F mixture is excessively rich. If that's the case, you better solve that before putting cats on. The rich mixture can foul the cats and they won't even do what they're intended to do.
stykthyn
5,232
2,652
223
gainesville
Dec 12, 2016
#10
  • Dec 12, 2016
  • #10
@MFE92 posted some nice emissions numbers from his car with cats and no smog pump. I wouldn't jump straight to the conclusion that you need to reinstall one if you don't have it.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 12, 2016
#11
  • Dec 12, 2016
  • #11
I honestly need to pull
Codes and go from there.
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Dec 12, 2016
#12
  • Dec 12, 2016
  • #12
If I'm not mistaken he ran these and it was some pretty interesting results.
https://m.summitracing.com/parts/mpe-53956
bigc2330
79
Dec 12, 2016
#13
  • Dec 12, 2016
  • #13
Open the garage door and put a fan in the garage!
Reactions: Boosted92LX and Davedacarpainter
02 281 GT
Agreed...My wife has great Boobs
3,208
1,973
194
Cabot, AR
Dec 12, 2016
#14
  • Dec 12, 2016
  • #14
If I recall correctly, the newer style cats on the market today don't need the thermactor system as they're far more efficient than the factory original cats that came on our cars. The original cats were far less efficient and needed the extra air from the smog pump to help the catalytic process during warm up. I think. I need to search for jrichker's write-up on the thermactor system and what it does. Pretty informative.
Found it: http://www.stangnet.com/mustang-for...springs-mega-power.886167/page-4#post-8919407
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 12, 2016
#15
  • Dec 12, 2016
  • #15
Many smog tests are visual as well as mechanical. I know around here, if all your smog equipment isn't hooked up and functional, you don't even need to worry about making sure it'll pass.....because they fail you before you get the chance.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Dec 12, 2016
#16
  • Dec 12, 2016
  • #16
Same here. No sniffer test, but if I show up without cats they won't even entertain the thought of a sticker.
I run a stock h pipe. I really need this change thst
Sent from my iPhone using Tapatalk
2011rustang5o
113
Dec 13, 2016
#17
  • Dec 13, 2016
  • #17
Why the hell are you starting your car with the garage door closed? No cats means your gonna have a smell.
stykthyn
5,232
2,652
223
gainesville
Dec 13, 2016
#18
  • Dec 13, 2016
  • #18
Sorry guys I'm in an inspection free state. I forget that others aren't in the same situation.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 13, 2016
#19
  • Dec 13, 2016
  • #19
no inspection or tests on classics here. Just looking deal with the smell. I'll post back soon. Got a couple things to do then I'm gonna start by making sure everything is running right under the hood before I mess with cats.
bird_dog0347
still married haven't seen testicles in years
2,326
2,081
174
Little Elm, TX
Dec 13, 2016
#20
  • Dec 13, 2016
  • #20
I have those same ones, and bought them for the same reason with likley the same setup. In my build thread there's pics of when I installed them into my BBK ORH. Just make sure to make an outline of sorts on some card board as a template before you go cutting on the H Pipe. You should just be able to search "squirts" and find my thread.
  • 3
  • 4
  • 5
1 of 5 Next Last
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox HAD ENOUGH OF EXHAUST FUMES!!!
  • PonyGTrider
  • Aug 12, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 13, 2024
PonyGTrider
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
R
Exhaust Exhaust smell in cabin
  • Rcdgl
  • Oct 16, 2024
Fox 5.0 Mustang Tech Oct 20, 2024
nickyb
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
