Hi all.
I just bought a 97 Cobra coupe that has a reman T45 in it. The car place I bought it from had the "new" trans installed. The problem is that the mounting bolt holes on the "new" trans didn't line up where the factory trans did and the mechanic had to slide the (double hump) crossmember forward about 5 inches. While it seems to hold the trans well enough, the crossmember is about 1/16th inch away from the heat shield of the driver side cat and tends to make unpleasant noises when the engine torques.
I showed this to a guy at the Ford dealership and they said that it is a T45 trans, it is just not the correct body for a 97. My options are to get the correct trans and relocate the crossmember where it should be or to get an aftermarket cat system.
I plan to go the cat system route just because it is cheaper and it will help performance. I was looking at some on Summit but the actual cat seems to be in the same location as the second factory cat (which is doing the banging). Anyone have any suggestions?
Chris
Chris
