srothfuss said:
Have you heard the quote: "There is no replacement for displacement?"
A stroker motor adds displacement by changing the amount of travel that a piston is subjected to in 1 revolution. This is accomplised by adding a longer rod and crank with the corresponding throw. And as Willys1 put it, by adding the "longer stroke=more horespower"
Just some background for you to help understand the concept: Take two motors with 347 cubic inches for thinking purposes
A motor with a short stroke and large diameter pistons will rev very fast and not produce a lot of torque.
A motor with a long stroke and smaller pistons will rev slower (slightly) and will build more torque
Torque is a measure of an objects resitance to twist or rotate
Now, HP is a measure of torque, so the more torque your motor has, the more hosepower you have (so to speak) This then negates the issue of reving slower.
Yes and No.... The additional displacement is a byproduct of the extra travel that the piston must do as a result of the longer stroke. There may be some additional torque as a result of the extra piston travel but it is negligable. The majority of the extra torque on a stroker motor comes from the mechanical advantage provided by the stroked crank.
Look at the two red lines. The distance between them is the length of the pivot for our crank "lever". When the crank lobe is horizontal, you can imagine its mechanical advantage. Lengthen the distance between those red lines and apply the same force to push the lever "down". With a longer crank though the same amount of force is applied to the piston head, you gain a greater mechanical advantage on the "lever" and end up with more torque on the output shaft of the crank.
You can shorten the piston rods to reduce the amount of travel on the pistons and still end up with a significant mechanical advantage. The RPM increase (mentioned above) comes from using a longer rod and increasing the amount of rotation of the crank vs. the movement of the piston.
In other words:
Given the same stoke of the crank -- The longer the rod to "more crank" travel you get, and the quicker the crank will rotate. Shorten the rod to reduce piston travel and you end up with a higher rod angle and less piston travel. The longer rods are also more effecient and make more use of the expended energy from the cumbustion mixture. The longer travel of the piston allows for longer burn of the combustion mixture meaning that there's more time and energy spent by that mixture in pushing the piston downward to rotate the crank. A significant amount of power is picked up as a result of that as well.
With the exception of some down force lost due to increased piston angle, torque is not much affected by the shorter rod and less piston travel. The same amount of energy is still being expended to push that piston downward and the same mechanical advatage of the crank is still there (again, minus a small amount due to the increased rod angle). Horse power is much more significantly affected. Increasing the rod length and piston travel will have the greatest effect on rev capability and HP.
Reminder: HP = Torque at RPM
This last pic may help to visualize the post.
Longer rods are used to deacrease the amount of rod angle in a motor. They're also more effecient at applying the energy expended on the piston head and converting that energy to linear motion to push the rod lobe as close to "straight down" (in relation to the crank centerline) as possible.
