sunil6784 said:Wow, excellent explanation daggar. nice pics too
poneypower89 said:So, is it possible for me to make a stroker engine without boring the cylinder walls??? What size would that be?
FoxFan88 said:so whats the point of someone spending over a grand in a stroker kit when they can get a junkyard 351 and build it up???
StangGT1995 said:Isn't there only like a 50lb difference between an iron headed 302 and aluminum headed 351 though? I remember reading about the weight differences on here at one time.
Daggar said:50 lbs of unsprung weight on the car isn't too big of a deal so long as we can move it to the back. hehe
Michael Yount said:"Unsprung" weight is actually a bit of a misnomer from a physics perspective -- but it is the term that is used. However, you're right -- the engine isn't 'unsprung'.
The 351-based motor is gonna weigh anywhere from 75-100 lbs. more than a 302 with similar heads (cast iron or Aluminum). Check out the shipping weights on FRPP's crate engines....351 block is bigger/heavier; as is the rotating assembly. So one benefit of a stroker is that you can have similar displacement (347/351) and power/torque in a 302-based package that weighs significantly less than a 351-based package.
Here's a great link that explains some of the pros and cons of different strokes/bores/rod lengths. http://www.victorylibrary.com/mopar/rod-tech-c.htm
StangGT1995 said:I don't think my 5'10, 165lbs of scrawny is picking up either without a lift...
Rick 91GT said:A stock block only weighs about 130lbs, a DART weighs a little over 160 and a Man-O-War weighs in at 225.
I can toss a stock 302 block around but damn that Man-O-War was heavy to lift into the back on my 8" lifted F-150..lol
I put a LT4 block and assembly int he back of my truck last night, it was one heavy ****** as well, no wonder those Chevy blocks take some much power.
Andy, I moved your little weight around last night
Daggar said:LOL... does it hold your doors open well? I should be able to get moving on that project again shortly after our vacation is over. Life is gettin in the way of the build.:damnit:
