Progress Thread Explorer / Gt40 Game
gearheadboy
1,425
177
84
Greencastle Pa
So I'm finally around to sharing some of my Explorer intake, GT 40 head build. Ya I know. I'm just playing. It's on the cheap but mostly for fun. I figured someone would like to look at it anyhow. I have lots of progress and pics along the way. I'll post stuff as I can. So it started with an intake I bought on Ebay.
I cleaned it up and removed some unused vacuum ports, drilled and tapped the needed bosses for my application.
Minor port work on the opening to make it measure 70 mm to make me feel better. It was close anyhow.
Can you say powder coated?
That's all for today. I'll post more later.
Reactions: elarm1
Thanks guys. After some sleep and a day of working I remembered where the rest of the pics were.
Found out the previous owner had removed the top plate with a drill. :shrug: So I had to use my handy left handed drill bit on one and my EZ out on the other.
Another shot of the throttle body opening. Yes I measured it. 68.86 or something. And I made it BIGger. My throttle body is 70 mm. Would it matter? Probably not a bit. But I can sleep better.
I chose to remove the pressed in tube at one end underneath and drill/tap it for a plug. I don't need this one.
You can also see in the background that I cut the long one that comes out the front off with a cut off wheel. I won't need it right now for anything and it is long and ugly. I'll cap that one.
Looks nice! Makes me not want to get rid of my GT40/Exploder intake. P.S. I think you should have sent the lower to TMOSS.
I talked to Tom via email and he told me I didn't need to port it with my combo. I would have liked to have it ported prior to powder coat but he is right. It will flow fine for this combo. I think this combo will be here a while.
Reactions: elarm1 and smkshw
