- Oct 18, 2005
- 145
- 0
- 0
Hello all,
:Word: I have a 96' Explorer with a 5.0. It recently started to hesitate. I has an AOD in it. It also has 195k miles on it. The best way to describe it is that it hesitates with minimal throttle. When it starts to do it if you accelerate to half throttle it almost stops. It does not matter which gear it is in. Wednesday I changed the trans filter, and fluid, added some lucas oil Trans fluid with it. No change. Friday I took it to a local mechanic, and he put a scanner on it. It was showing that the #5cyl was missing. We pulled the plug and it was leaned out. I figured bad injector, replaced it, cleaned the throttle body, upper/lower intake...no change. Any ideas?
