explorer tb install help for fox body
westridez
68
i got a gt 40 explorer intake on my fox i put my stock egr spacer and tb on it i have the explorer tb that came with the intake what would i have to do to convert the explorer tb to work on my car also what size is it in mm and what size is the stock one? what about my egr spacer i dont have any emmisions left and the egr is disconnected i seen a thread on here about this before but i did a search and cant find it.
thanks
Stock TB is 60 mm.
The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
A trip to the welding shop with the explorer TB and the arm from your old Mustang TB would probably accomplish the same thing. I didn't have access to a welder, so I fabb'ed the plate in my shop. I took about 1.5 hours to do it, it was a measure, cut, and fit type of operation.
This is what I did:
Make a drawing of the position of the old throttle body linkage arm and its angular position relative to the centerline of the throttle body. Remove the ball stud off the explorer TB to make way for the adapter plate. Drill and tap a 10-32 hole in the linkage parallel to the TB shaft. Make an angle bracket out of 1" angle iron 3/8", drill a 3/16” hole in the center of each one of the legs. Then bolt it on where the hole was drilled & tapped. Then make a circular adapter plate out of 1/4" thick aluminum to bolt the two linkage arms together. Then bolt the aluminum plate to the existing linkage, and the angle bracket. Next mount the arm with the ball stud off the old throttle body on the adapter plate using the drawing to get the angle correct. You will need an aircraft type countersink for one of the bolts that secures the plate to the explorer linkage arm. It ends up being under the arm with the ball stud for the linkage. It works great and looks neat.
Also see Tmoss's adaptation technique at http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Another method is to remove the old bracket from your old TB by grinding off the end that is mushroomed over. Do the same thing to the Explorer TB and then drill and tap the shaft for a 10-32 machine screw. Put the bracket from your original TB on the Explorer, and install the screw with a big washer. You might want to put some Loctite on the screw threads before tightening the screw down.
jrichker said:
Stock TB is 60 mm.
This is what I did:
thanks for the info do you have a pic of your tb the way you got it set up im kinda confused on this. but i do have a mig welder
I have taken the stock tb apart and notched the shaft to except the explorer throttle plate. Installed the modified throttle shaft in the explorer tb and mount the explorer plate to the throttle shaft. By doing this everything bolts up to the fox body throttle linkage.
I took the fox stock tb and ground the weld rivit or what ever it was off the center of the linkage plate. Pryed off the linkage and did the same thing to the explorer tb. I slid the fox linkage plate onto the explorer tb and it put everything just as it should be. You could JBweld thelinkage plate to the shaft or if you have a welder put a tack weld on it. Its simple and looks stock. Nuttn to it. if you dont understand what I mean look at a stock tb turn it upside down and look at the center of the linkage its mashed or rivited or welded, just grind it flat and pry the whole thing off. the explorer tps is differnt than a fox tps the blade sticks up higher on the explorer tb so grind it down a little for the fox tps to fit.
I used the Tmoss guide. that is posted above.
I kinda went this route. Took both tb's apart to make sure the shafts were the same length but instead of notching the shaft i notched the plate from the explorer tb to fit the mustang shaft. Everything bolted up fine. Was able to set the tps voltage to .90 without making any other modifications.
what did you do about the egr spacer
:stupid:
I've done that a few times myself!
westridez,
I had taken my stock egr spacer to work and machined it out to 65mm. This was done by setting it up in the lathe to do this. Took me about 1 hour to get it within .005 of being exactly straigh and square.
